Hi All, sorry if this was already mentioned (I could not find it though) - is the Fiio EM5 worth to buy? Moreover, any comparisons with the Aiwa HP-V99? Because I saw that the V99 inspired the EM5 in the first place and I became interested. Cheers.
Bass is very clean and is fun at the same time due to the boost. Speed, tightness and texture are top tier.
Mids are excellent with very good tonality for both male and female vocals and clarity/detail are very good despite the high bass quantity.
Treble is airy as most buds are and treble extension is good as well, very non-fatiguing but detailed treble.
Technicalities are very good but most notable is the huge soundstage and that the timbre is excellent as most buds.
Comparison with the Yincrow X6:
The sub-bass is lower on the RW-2000 and doesn’t rumble as much either. Extension is similar. But otherwise, the speed, tightness and texture are better on the RW-2000 while the overall bass is very similar.
Mids and treble are a lot better on the RW-2000 and the tonality is brighter than the warm X6 and is more neutral than the X6.
Technicalities and overall resolution are leagues ahead on the RW-2000.
This might be my favorite bud and worthy of being called a TOTL bud.
I think MX500 shells sits in my ears a lot better. I'm not sure if it is the smaller diameter or protruding shell of the RW-2000, but I cannot get them to stay in place for long without having to readjust. Maybe this can be fixed by wearing them with ear hooks or cables behind the ears but it is not what I particularly like to do with earbuds. I tried stacking multiple foams but ended up just using very porous VE foams.
Fit was the main reason I did not keep this pair but I still miss its sound at times. Maybe I'll get another pair sometime later.
I think I could have fixed the issue with with some rubber rings or something. If you can get a good fit out of the box then it's a keeper. I cannot name another pair similar to it for the price and performance. Not to mention the built quality and cables are really good too.
I wear the RW-1000 over ear with the driver angling in slightly so that they are firing direct into the ear canal. This is the best sound and most stable fit (when stationary) for me. YMMV.
Edit: Pull the cable tight using the chin slider when used over ear. This helps with fit stability
You could use the following cheap porous and thick foams. Then you could cover it with red and blue donut foams to make double foams and increase the bass. https://www.aliexpress.com/item/33019313027.html
