I use JRiver as a player,possibly inconsequential update: I've dusted off my old macbook and will be testing system-wide eq implementations.
Mac OS users, what are you using?
but I don't use a system-wide eq.
Just "run away" the next time you come across these shells. They kill the soundI believe this is an overpriced version of the lower-priced Headroom MS16
Personally experimented with this, and it's true.
Looks can be deceiving. I couldn't believe it when I opened them. The design is a total failurePersonally experimented with this, and it's true.
haha, you don't see me running this is just one of my favourite earbuds, in fact, my top 10s..your image and your post had other earbuds and even the described image stating the MS16 is not showing the same shell shape at all, this is the case of mistaken identity,(wrong earbuds you're calling out)
Haven't tried MS16, I don't think so though.I believe this is an overpriced version of the lower-priced Headroom MS16
I didn't talk about the driver, which is ok for budget-friendly earbuds, but about the shells. I tried a few high impedance DIY drivers, like 400ohm graphene andhaha, you don't see me running this is just one of my favourite earbuds, in fact, my top 10s..your image and your post had other earbuds and even the described image stating the MS16 is not showing the same shell shape at all, this is the case of mistaken identity,(wrong earbuds you're calling out)
Everyone I know who owns it has stellar comments on it
It costs you nothing to try. Most of the earphones can benefit from a break-in process.Just received the yincrow X6, its okay for its price, but for price to performance ratio I'd still consider the Koss line-up more bang for the buck.
Does the X6's need burn-in? so far liking the donut foams more than the full foams, more transparent overall though mid bass I think is more boomy, but better tonality than full foams, YMMV.
NiceHCK B40Budget PK shelled, preferably flat sound signature?
NiceHCK B40
But smaller than MX500 shell.That's bigger than PK though.
