Earbuds Round-Up
  1. palestofwhite
    I see... I'm actually not looking at swapping the cables frequently but more of when it gets faulty. I think that due to high humidity or sweat, the cable of my black Kube 1.0 which comes into contact with the skin has already started to harden and shine. I think the next stage will be the rubber insulation crumbling, just as how my older earphones failed from experience. I see this MMCX solution as a double edge sword as all my earbuds come with fixed cable.
    mbwilson111 likes this.
  2. mbwilson111
    That sounds like a good plan. I think the connectors are good enough to withstand a few changes. I just know that some people take cables off every time to put the bud or iem away. I would not do that.
    I am not sure I remember where you are. Not much humidity here. You would probably laugh at what they call humid here.
  3. palestofwhite
    I know it sounds crazy, but humidity here is all time hovering about 70% and sometimes above... :D
    If I had to choose, I would take 2-pin over MMCX. Do you happen to know if the fixed cable version of the RY4S Plus are actually similar sounding to the MMCX model? Maybe I should just go for that instead, because I just realised that the MMCX cables are sold separately and all my existing cables are 2-pin...
  4. mbwilson111
    Is there a version of the RY4S Plus with fixed cables? Which one were you thinking of?
  5. palestofwhite
    I think I might have gotten it wrong but they have the RY4S HI version... Not sure if they're same as the MMCX Plus though...
  6. BadReligionPunk
    I think the plus has a new driver. It sounds totally different then my ry4s UE. IMO much better sounding then the UE. No idea on the HI ver. though.
    chellity, mbwilson111 and HungryPanda like this.
  7. robar
    Wow, I thought UE and Plus sounds the same or the difference is minor due to the shell modification. (I only have UE) In what aspect do you find the Plus better? I suppose bass is bigger, but are the mids smoother more natural as well? My main problem with the UE is the thin, slightly metallic and peaky tonality. (can be fixed with EQ but it's cumbersome for me especially with Windows)
  8. toear
    The info I got from the seller was that the HI is the cabled version of the MMCX Plus. The HI/Plus version sounds 'better' than the UE. I have the UE version and love it. Just ordered the MMCX Plus version with 'fancy' cable because the Plus version has free shipping but the HI version charges and extra $4. I figured I would splurge and get detachable cables.... :p
  9. robar
    It's weird I read comparisons between HI and UE in the past and people said they're basically the same. Also HI is cheaper than UE. I'm getting tired of this constant ambiguity with chinese products. Aren't all RY4S have the same driver, just with different tunings?
  10. Willber
    Luckybag landed. Lovely, like lots.
  11. snowmind
    Hello everyone, how pleased to find this centralized discussion of buds. I have RY4S common version (not UE / Plus), Qian69 and Qian25.
    Qian25 is powerful and very dynamic, warm side of sound and neutral signature. I'm waiting for my lucky bag and the new neutral-tuned white Vido.
    ValSilva, Willber, DBaldock9 and 2 others like this.
  12. HungryPanda
    Welcome to the thread
    DBaldock9 and snowmind like this.
  13. robar
    I love Qian25 :) FYI new white vido is basically the same as the old one, so v shaped bassy.. more balanced versions are y cable blue and probably red, black. Or is there a y-cable white also? I've never seen one
  14. DBaldock9
    Welcome! You're starting out with some very good, budget priced earbuds.
    HungryPanda likes this.
  15. phthora
    Your alliteration is magnificent. :clap:
