Marcos Fontana
Happy birthday!!!!Today I turned 50 years old .. I have the right to rest from the Internet, thanks for the concern )))
Maybe Monk Lite? I don't know it, I have the Zen LL and it's great! Zen LL has the same shell that Monk Lite. I believe that Qian39 uses the same shell type of Monk Lite. PK2 shell are smaller too, in this case, the SR2 tpe 16ohms.What are the go to choices at $30 and under? Preferably small shell
You won't find the EBX as an upgrade from ACG. It has completely different signature, less impressive in detail retrieval and transparency. You might be disappointed if you expect similar mids from the EBX.Any recommendations on an upgrade to the Ourart ACG (or even a sidegrade with bass)? Preferably with MMCX as well. Something with great mids/highs but actually has sub-bass and bass.
I've been looking at the EBX or maybe the new ST-10, but not too sure where to leap.
@HungryPanda could you give a brief explanation how you determined the driver was out of phase? Noticed on some of my earbuds that the L & R drivers were not marked similarly.Edifier do have some very good sounding earbuds. On another note I disassembled my K's K200 as it sounded really bad. I put the drivers in new MX500 shells with a new cable and whilst doing so found that one of the drivers was wound out of phase ( hence the poor performance). Now that has been sorted they now sound very good indeed. Thunderous bass and really clear highs. I'm glad I did it.
Ok thanks! Makes sense...I didn't change the tuning foam that was on the driver so I think the shell cavity of the MX500 shell has increased the bass from the MX760 shell
I found the cable was attached correctly but the 2 drivers were wired in the opposite direction. one had + on the left side but the other had - on the left. The dot that marks + on each was in the same place.
Easily done I suppose. I get multiple drivers for my own buds and they come marked for the + and can be on either side, so they have been checked. I always use a multimeter to check cables before I use themSound like an assembly error down at the factory.
hi,newbie here. so a guy on facebook told me that he prefer his 50$ earbuds over his 200$ iem and want me to try it my self. i used to think that headphone > iem and earbuds until recently got my hands on moondrop KPE and fell in love with it is there any earbud around 30-60$ that have the harman sound ? what earbud would u guys suggest to an earbud newbie ?
No earbuds will have harmann curve sub bass. It's almost impossible with the lack of seal. There's some earbuds that perform admirably in sub bass but it will follow more closely to the diffuse field neutral sub bass or slightly less.hi,newbie here. so a guy on facebook told me that he prefer his 50$ earbuds over his 200$ iem and want me to try it my self. i used to think that headphone > iem and earbuds until recently got my hands on moondrop KPE and fell in love with it is there any earbud around 30-60$ that have the harman sound ? what earbud would u guys suggest to an earbud newbie ?
