Earbuds Round-Up
post-14719781
Post #39,017 of 47,131
seanc6441
Ireland
Ireland
Reactions: KevDzn
post-14719848
Post #39,018 of 47,131
KevDzn
Thanks very much. I registered and will PM the seller when I can for Victor and Docomo buds
If you're able to get it, remember to get extras coz they come with y-cable. I'm sure you will want to re-cable it.
post-14719873
Post #39,019 of 47,131
Carrow
Ireland
Ireland
How did you find docomos?
I second this question. I'd love the stock standard docomos so I can have a pk bud again. I have the pk sr2 but need to burn it in. But I also want that warm bright tilt offered from my cygnus (which is a docomo driver with upgrade cable I believe) so I'd love a docomo bud... Or two.
@Carrow
Also how on earth did you get the JVC Victor. That's all people can talk about on earbuds anonymous lately lol. They must be good buds.
Through Michelle Ong in EA :)
post-14719917
Post #39,020 of 47,131
seanc6441
Ireland
Ireland
What are the extras? You mean like recable?
I would want to do that myself. But if by extras mean sosomething else please do tell.
Btw, why are the JVC branded ones cheaper than the Victor branded ones. Do they sound different? Thanks
post-14719992
Post #39,021 of 47,131
RuFrost
any comparison between bs1 official and to400s? and alike earbuds?) For example, Lyra Collection. (really seeking to try it!!!)
post-14720003
Post #39,022 of 47,131
Carrow
Ireland
Ireland
I can never be sure if it's Yin-yoo or Yincrow we're not allowed discuss in this thread. (or on HF anywhere) @RuFrost
edit: apparently it's Yin-yoo so you should edit your post to be on the safe side :)
Reactions: RuFrost
post-14720017
Post #39,023 of 47,131
waynes world
The Cubu and V1 do sound very close to the same. For whatever reason I thought they sounded just slightly different, but in a blind test I most likely could not distinguish between the two earbuds.
Huh! Very interesting. Thanks for sharing that.
post-14720352
Post #39,024 of 47,131
CyberGhost
Does anybody know why there seems to be two versions of MusicMaker MrZ Tomahawk? There is one with the MusicMaker logo and then there is another with the Z in the middle.
One says Toneking the other Music Maker. These seem to be the same.
What are the differences, if any?
Also, what about MrZ Ting, how does that compare to Tomahawk? Chinese sites (Aliexpress) seem to comparing Tomahawk to MX 985, does it sound like 985s?
Reactions: KarmaPhala
post-14720387
Post #39,025 of 47,131
Willber
Southampton, UK - *I use EQ*
post-14720392
Post #39,026 of 47,131
mbwilson111
I think by "get extras" he means get more than one set.
Yeah, in case you kill a driver during a recabling effort. It happens.
post-14720404
Post #39,027 of 47,131
seanc6441
Ireland
Ireland
To400s. Linear sound. Analytical. Considerable bass roll off, lacks depth and punch. Treble dips slightly but has an emphasis around 10khz for air. Overall it's like a more technical shozy bk without the mid bass punch.
Bs1 O. Warm medium full bass but not too deep. Slightly bright tilting mids but has enough vocal body to carry a presence. Really musical. Nice smooth lower treble and slight emphasis in the mid treble for sparkle, slightly rolled off upper treble. One peak around the upper mids (maybe 3khz region) that throws off tonality a bit, but not determental unless you want neutrality.
Both retrieve lots of detail. But fall short on overall extension and sounding 'dynamic'. I imagine they would make good earbuds to try out in mx500 or other more ported housings, but that would be costly lol.
Reactions: RuFrost
post-14720408
Post #39,028 of 47,131
seanc6441
Ireland
Ireland
Thanks you are right. Makes sense.
Bought 2 kube buds and will buy 2 Victor/2 Docomo buds. Only bought one SL1.0+ but i can get that again if I need too.
I usually buy 2+ budget buds if im modding, easier to A/B that way to see if I prefer the mod or not.
post-14720445
Post #39,029 of 47,131
seanc6441
Ireland
Ireland
Anyone still have the Rose Mojito in their rotation? Anyone still finding the treble too piercing for long durations?
I think I found a suitable fix, one that requires no EQ.
As you see the central vents allow the high frequency driver to expell sound. The outer vents produce the bass.
If you can buy filter paper its a great treble damper, but it also messes up bass by restricting airflow. However with the rose buds, you can dampen the treble and leave the bass untouched if you place the filter over only the central vents and leave the very outer row uncovered. You can use this in combination with foam and silicone ring (from the VE ex-pack) to potentially remove most treble peaks and balance out the sound.
Currently im using one ply of 'surgical mask' paper filter which was recommended for headphone modding. In combo with ksc75 foam liner, and a VE ex pack silicone ring. It's worked very well. It doesn't dull the sound clarity is retained but treble is under control now.
Sibilance is notably reduced, the treble is no longer brittle sounding (i think a peak in the very upper treble was causing this). Everything sounds damn good with it now. Bass hits moderately hard with the silicone ring alone, surprisingly. But it's clean and without mid bass bloat.
Dynamics are more impressive than ever, something the mojito always did well, now it does it without sounding artificially achieved through crazy FR.
post-14720459
Post #39,030 of 47,131
Danneq
Stockholm, Sweden
Stockholm, Sweden
It's the the same. It's the maker that changed name from MusicMaker to Toneking. It doesn't really sound like MX985. It's got good extension at both ends but some find them a bit too bright. I'd say they've got a slightly "metallic" sound and work best with hard rock or metal. I keep my pair because of the great synergy with those genres.
Users Who Are Viewing This Thread (Users: 15, Guests: 43)
