Earbuds Round-Up
post-14663091
Post #38,326 of 49,981
redkingjoe
Wow!
It was released after I bought my pair of ZF. There might be a small difference but I think ZF is good enough. Hope you like ZF too (even if the cable is a bit stiff).
Frankly, I won’t believe you would be settled with something that’s only good enough!
post-14663131
Post #38,327 of 49,981
Danneq
Stockholm, Sweden
Stockholm, Sweden
Well, after Swedish customs became strict and added import tax and customs fees to ALL packages from outside the EU, no matter the declared value, I have to start to settle with what is good enough. :cry:
post-14663223
Post #38,328 of 49,981
j4100
Glasgow
Glasgow
I was starting to think my Fengru DIY PK1 2.5mm buds were not going to arrive, but here they are! Trust me not to have a 2.5mm to 3.5mm trs adaptor at work :)
Only waiting on my Black Friday RY4S delivery. And my late fall edition monk. And my Rholupat order. Happy days.
post-14663329
Post #38,329 of 49,981
LazerBear
Hi. I've been following this forum for a long time and first of all I want to say thank you. I'd like to have some of your great advice. I don't feel comfortable with IEMs and at the same time I don't feel comfortable to give them to someone. I want to give good quality earbuds round-up to my girlfriend. What can you suggest me in the range 50-100 euros? If it's possibile, something I can find on Amazon Italy to get a faster delivery.
Welcome! First of all, since it seems that you don't have much experience with earbuds, I think I should point out to you that earbuds normally have a series of issues which IEMs normally don't: mainly lack of isolation and lack of sub bass (and more generally attenuated bass). That means that using earbuds in an even slightly noisy environment is not recommended.
If you're fine with that, let's move on to earbuds recommendation: you can find a nice recap of well-regarded earbuds in this post, courtesy of @Marcos Fontana: https://www.head-fi.org/threads/earbuds-round-up.441400/page-2540#post-14638000
If you can expand a bit more on your sound preferences, we can give you an additional hand sorting out those from the list that might not be appropriate. Keep in mind that a lot of the more expensive ones are in the 100+ ohms, which means you will need a good source powering them. If you're planning to use a cellphone, you should look at 32-64ohm max.
post-14663333
Post #38,330 of 49,981
DaniErre
Italy
Italy
Thank you! :D
post-14663337
Post #38,331 of 49,981
LazerBear
So, I've received the NiceHCK EBX and.. surprisingly I like it less than the EB2. Might have something to do with the fit, but I feel the highs are a bit too much (whereas the EB2 strikes a very good balance between extended and non-fatiguing) and does not correct the dip in the mids that I perceived in the EB2 enough to warrant me keeping them.
I'm thus adopting a two-pronged strategy: on one hand I'm trying to see if I can score a Rose Masya as an upgrade to the EB2, on the other I'm looking for advice for a darker set of earbuds in the 20-80$ range that can complement the EB2 for busier genres such as metal, hard rock etc.: any input would be greatly appreciated, I am currently looking at the 1More E1008.
post-14663478
Post #38,332 of 49,981
redkingjoe
I remember that you travel extensively! You can just ask them to ship to your hotel!
When I was in Taiwan or USA, I simply asked the shops to courier them to my hotel.
Reactions: chaiyuta
post-14663571
Post #38,333 of 49,981
Danneq
Stockholm, Sweden
Stockholm, Sweden
Nowadays we mainly go to Japan to visit my wife's mother and we stay at her place south of Tokyo. I have bought stuff from Yahoo auction and had it sent to her. I did that with the Moondrop Liebesleid that I bought this summer (and later sold here on Head fi).
That works pretty smoothly compared to have it sent to Sweden.
post-14663735
Post #38,334 of 49,981
jogawag
I recommend "DIY SR2 16ohm TPE wire" in AliExpress with about $15.
The strong bass sound as PK-type fits for busier genres such as metal, hard rock etc. And this earbuds are not bright.
I recommended this silver plated cable version before, but it seemed that sounded a bit too bright.
This earbuds need 200 hours burn-in.
This Earbuds looks cheap according to the price, but you will be amazed by this powerful bass and wide sound stage.
I feel this to sound comparable to SWD2+ and I have been using this all the time especially outdoor for the last 3 months.
https://www.aliexpress.com/item//32801646835.html
Select the 2nd in "Color:".
post-14664574
Post #38,335 of 49,981
doggiemom
Wow, these Sabia V6's are good.
Yeh! You got them! What do you think????? I ordered a second pair for work, now that they seem to be in stock consistently. IMHO they are a great bang for the buck.
Reactions: DBaldock9
post-14665105
Post #38,336 of 49,981
Willber
Southampton, UK - *I use EQ*
post-14665155
Post #38,337 of 49,981
atmosfearz
Russian Federation
Russian Federation
Hello, can anyone suggest some really good earbuds for ES100 (I've just decided to not take Pro82 everywhere). This thread is a really mess, I gave up after ~200 pages. Firstly, my sight was on Rose Masya (It looks fabulous), but then I found a lot of choices, like DX3s, EBX, Linsoul BLD, BS1, E1008. Most of my music are rock.
post-14665182
Post #38,338 of 49,981
Marcos Fontana
Brazil
Brazil
Hello, can anyone suggest some really good earphones for ES100 (I've just decided to not take Pro82 everywhere). This thread is a really mess, I gave up after ~200 pages. Firstly, my sight was on Rose Masya (It looks fabulous), but then I found a lot of choices, like DX3s, EBX, Linsoul BLD, BS1, E1008. Most of my music are rock.
Hello!
Check the list in my signature. Some that are amazing: Svara L, TY HI-z 650ohms, RW-9, RY4S UE Cable and many others. Depends on how much do you want to pay.
Cheers
post-14665186
Post #38,339 of 49,981
Sgt. Ear Ache
canada
canada
don't start from the beginning of the thread. Just go back to about 20 or so pages from the last page and start from there. Should get some good ideas...
post-14665216
Post #38,340 of 49,981
atmosfearz
Russian Federation
Russian Federation
The only thing I missed from last pages is Moondrop VX Pro.
Users Who Are Viewing This Thread (Users: 22, Guests: 38)
