- Jan 10, 2016
If you prefer a smoother sound, ShoonTH ESEP-01BU. The D2+ is technically better but cost 100 USD more so no surprise.D2+ sounds outright better to me then
Seems to be a trend for new TOTLS announced... It's going the route of high end IEM's it seems.
Thanks, I've already read the review but what I need is a compare between TM9 and Blur Dark Chocolate. I really appreciate it.
He told me the same when we met in Tokyo in July. I brought my pair of CampFred 1 and he asked what foams I was using. I replied that I use thin VE foams. He said that he tunes the Cypherus earbuds to be used without foams. I used thin foams at first with ZoomFred but then switched to rubber rings with fins from the VE EX pack (but with the fins cut off). That's when the ZF really found their perfect sound. I do think that other Cypherus earbuds work well with foams, but mainly thin VE type foams because of the already good bass.
Moondrop liebesleid is a detachable cable earbud??? :O
If you have a high quality cable, try it. The image of moondrop you know will change.
It's applying a bass boost filter below 100hz probably?Lmao what the hell are these Walkmans, I thought about trying them with the buds I have left, the TO400s is unreal, its fixed now, the bass hits to hard. Even harder and better than the Samsara....the EB2 is fixed as well...the bass these earbuds output now is screwing ridiculous...not much effect on the monks tho lol
EDIT: To detail on the monks, they do accentuate it but they cant control it well so I am not sure yet if its worth it
They look a million dollars! The style is always on point.You guys really need to get into trying Moonbuds. I got the nightshade and am seriously impressed. It's a bit of a leaner sound in comparision to TM9, and the technicalities are excellent.
If that's a mod it's absolutely fantastic because the connector and shell look all one piece. It's gonna change the tuning though unless the original stem was made completely airtight by the cable...Cool mod! Did you do it?
That BK is a very good earbud. Have you already heard the endgame earbud that beats it? If so, what is it?Selling some earbuds in the FS section if anyone is interested. Bk 2.5 balanced included.
