Does that amp have that warm full sound associated with most tube amps? If so I can see how the eb2 would be a nice pairing in that case.Sounds like what I'm looking for. I'll be using it with a hybrid tube amp mostly at my desktop.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Lothar101
I'm using different tubes than the stock ones and it is somewhat warmer. I think it brings out the details more. I should roll the op-amp in it as well but overall pretty pleased for when I get a chance to just sit and listen. Reminds me of my old Marantz receiver I had in the late 70's.Does that amp have that warm full sound associated with most tube amps? If so I can see how the eb2 would be a nice pairing in that case.
silverfishla
The EB2 is a good bud. It has a really good clear vocal section. It doesn’t have a very defined bass section though. It’s hard to tell a bass note from a kick drum, for instance. It has nice separation ands a wide soundstage.So the EB2 would be a noticeable upgrade in sound from say, MX500 Bro (earbud) or Vido or Monk+ for example then? I still haven't seen a review anywhere on the MX500 Bro from NiceHCK. Any difference in size from MX500 shell? Also looking at the Faaeal Datura-X. Want a full rich sound with greater details than the MX500 Bro.
The Datura X also has a pretty wide soundstage but it is altogether fuller sounding and more balanced. It has a bigger and more defined bass section. I like it better, but enjoy both.
The EB2 is small and comfortable while the Datura X is built very sturdily but also very comfortable. I like the braided cable on the Datura better than the encapsulated cable on the EB2. Both are nice, though.
snip3r77
- May 13, 2010
A lot will be buying both because of this EVIL haha
waynes world
- Jun 21, 2012
Well, I can vouch for the Datura - a lotta fun!
Agreed but only on some tracks it's apperant that's why I boost the sub bass but don't touch the mid bass. Not because it's particularly mid-bassy or bloated but I feel like the bass needs to be tilted slightly to separate the sub bass from the upper bass. Adding a few DB at 16-32hz and boosting the 650hz 'low mids' helped define the bass.The EB2 is a good bud. It has a really good clear vocal section. It doesn’t have a very defined bass section though. It’s hard to tell a bass note from a kick drum, for instance. It has nice separation ands a wide soundstage.
There's also the question of how the foams are covering the back ports. The EB2 is particularly open on each side as much or more so than mx500 shells. How much foams are reducing the airflow would have a big impact on the low end performance.
Thicker foams would actually restrict more air flow and possibly tighten up the bass while helping sub bass impact with the seal.
What foams are you using out of curiosity?
silverfishla
I know! So evil!A lot will be buying both because of this EVIL haha
I'm using those $1 for a 100 Aliexpress foams. I find them to be the best for these two buds. I've used full foams on the EB2, and it brings up the bass...but it kind of floods out the best parts of that bud, and doesn't really add definition to the bass. So, I let it do what I think it does best and leave it at that. Still, I like it.Agreed but only on some tracks it's apperant that's why I boost the sub bass but don't touch the mid bass. Not because it's particularly mid-bassy or bloated but I feel like the bass needs to be tilted slightly to separate the sub bass from the upper bass. Adding a few DB at 16-32hz and boosting the 650hz 'low mids' helped define the bass.
I don't use EQ, because I don't use my buds on my my computer (I could do it with Audinirvana or JRiver). I usually use them straight from a DAP or with my DAP and portable amps. DAP EQ's pretty much stink (at least the ones that I have). So, EQing a bud for me, is not really an option (maybe the AP80 with the Mage8 EQ/DSP might work, but we'll see when I get that one).
because my curiosity on the EX1000, a really nice friend of mine lent me his so i could try them out. now that i have tried them, I'm not lusting too much about it anymore, because the Samsara (and also the PS100-500) is pound per pound can match it's performance, and without the fatiguing treble of the EX. it does have a great large soundstage for an IEM, but in the earbud world, that size is more common. so in the world of semi-open IEMs, I'd rather put my money on even the same priced earbuds counterpart. muuuch better sound to price ratio in my personal opinion.
when compared to the closed IEMs, especially those with BA or hybrid tech however, then the choice might be more complicated, because they have different sets of weaknesses and strengths
Lothar101
Well, I ended up ordering the EB2's I'm hoping a warm sound source will make the difference for me. Really looking for more detail at this point. It isn't a search for the holy grail but would like a full sound across the spectrum. At a later point, I will be looking for the grail but can't afford at this time.
snip3r77
- May 13, 2010
Why does EB2 need a warm source?
golov17
QLS 361?
Willsound MK1 Special Edition
Zerohour88
now that's tempting, was just discussing with a friend about ordering the EX1000 (or at least the EX800ST) since they're still comparable to even the Andromeda. Which version of the PS100-500, may I ask? looks a lot cheaper than the Samsara (if my googling is right).
snip3r77
- May 13, 2010
Can help compare with those totl more than usd100 de ?
