Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Which one of them benefits the most from a balanced cable, TinAuduo T2 or PT15?
TinAudio T2 of course
agreed. T2 benefits greatly from balanced. strangely, I like the PT15 more with SE cables..
Just received today my NiceHCK DIY PK2, and couldn't resist for a quick first listen to work with VE full extra thin foams, but was immediately disapointed by the sound. Nothing extraordinary, absolutely no "wow" effect, thin soundstage, absolutely no bass (no need to tell for sub-bass.), only vocals and highs looks ok (even if could do things much better).
As they sound out of the box, I guess they even don't deserve to get on my burning desk, as I really doubt they will change with time.
Definitely, Willsound MK2/MK1 sounds like a TOTL compared to these. Outch!
kurtextrem
For me the Svara-L is not uncomfortable, but it simply doesn't fit my ear because of the size.I can't speak for the EBX's, but I find the Svara L's to be very comfortable. Prior to getting them, I could never wear earbuds over ear, but the Svara L's work very well over ear. And they look very cool (I feel like I am wearing designer earbudware lol). The only downside for me is that I can't use them when falling asleep (which is probably a good thing so that I don't destroy them).
Just asking, it's Y i n y o o & not Y i n c r o w that are another banned seller on here right? I almost mixed them up even as I was typing this, so let me know which one it is for future reference.
Yes. Infact it’s hard to call between balanced and V shaped. Feels like it adapts to the music in question at timesThe Ling sounds like my pint of beer!
Well a few more pints if you look at the price
But only the cheap stuff because you won’t be able to afford it after your purchase
I did try warn people that they don’t sound good with stock foams. I use mine with modded foams that involves some cutting and my pair is burned in for maybe 50+ hours. They sound good to my ears maybe slightly less well rounded than the PT15 but I’ve only just discovered that sound and i think its the best under $20 for all round use.Just received today my NiceHCK DIY PK2, and couldn't resist for a quick first listen to work with VE full extra thin foams, but was immediately disapointed by the sound. Nothing extraordinary, absolutely no "wow" effect, thin soundstage, absolutely no bass (no need to tell for sub-bass.), only vocals and highs looks ok (even if could do things much better).
So, my love affair with Willsound buds progresses.......
Just received the Willsound mk.2 ootb they’re impressive. Strangely I find that if alternate between the mk.1 and mk.2 I need a couple of clicks more volume on the mk.1??? I thought both were 32ohm?
Mk.1 definitely has deeper bass, whereas mk.2 seems to have a bit more in the mid-bass. Mk.1 seems to have a slightly bigger soundstage, but mk.2 only has about 30 mins burning in.
Guggga
- Jan 6, 2011
Hey man, try and give earbuds / new gear a week's time after receiving to allow the sound to open up and also for your ears to reset from the sound of the gear in use.
Coming right after the mk2 rev 2 it's no surprise that you find the pk2 lacking. The mk2 have a very musical sound whereas the pk2 are kinda analouge and dry. The pk2 need burn in, lotsa burnnnn !
Here’s a good example of a relatively easy foam to cut and makes the pk2 much better sounding.I did try warn people that they don’t sound good with stock foams. I use mine with modded foams that involves some cutting and my pair is burned in for maybe 50+ hours. They sound good to my ears maybe slightly less well rounded than the PT15 but I’ve only just discovered that sound and i think its the best under $20 for all round use.
VE donut, with a few cuts on 5 sides to make a sort of star shape. The cuts basically just to allow more treble through than stock think donut. If you have these foams I’ll show you how I cut it with a picture. This was fairly easy to cut.
Ok for PK2 will try these tips, and give some burn'in, let's see in few days thanks
oh and don’t be afraid to apply strong EQ if you’re source can do it. I applied a big U shape EQ as shown and after that it sounds like most earbuds in bass and treble... By default these are overly mid centric and boxy sounding.Ok for PK2 will try these tips, and give some burn'in, let's see in few days thanks
With these mods and EQ its like normal earbud but with very detailed vocals.
Got a Willsound MK1 Rev 2 OTW thanks to @subwoof3r, and I just ordered a FAAEAL Z-Sound 32 off their official AE store; as well as a Vido off AK for Schitts and giggles. Much earbud, wow.
If your ears can fit them, i would prefer MX500 style shell than Yuins everytime. The Yuin shell will always lacking extention in the lowest bass and highest treble.. Not to say it's not possible (I've heard modded yuin shell that have big subbass, for instance), but still, given the same treatment, the MX500 shell would just have a better potential because of the bigger body.
The only argument that i would choose yuins is for nicer and more flush fitting
snip3r77
- May 13, 2010
congrats, that right there are two of my favorites too
the EMX500 have deeper and bigger bass
But pt15 owna graphene but
Sounds like what ToTL?
