Earbuds Round-Up
Nov 20, 2017 at 8:57 AM Post #25,036 of 75,134
Changed first to show ranking result.
Please watch the "Earbud Survey" ranking result and vote for the ranking!
I think that this would be a reference when purchasing new Earbuds.
You need Google ID(like Gmail).
Price is divided into 5 tiers of /$0→, /$20→, /$50→, /$100→, /$200→.
You can vote 1 - 5 rating to any earbuds which you've used and can submit form. Then you can watch the new ranking result. The URL is as follows. Enjoy this!
https://goo.gl/gt1THD
Nov 20, 2017 at 9:05 AM Post #25,037 of 75,134
may i ask, where did you source those 3.5 mm connectors?
thanks..
Those are parts of the "Neutrik NTP3RC-B Plug 3.5mm Right Angle Black/Gold" connectors, that I ordered from Zack Electronics (they have the lowest price I've found in the USA).
http://www.zackelectronics.com/neutrik-ntp3rc-b-plug-3-5mm-right-angle-black-gold.html
Using a technique shown to me by Wong Kuan Wae, I take the right-angle part of the shell, and place different 2.5mm & 3.5mm plugs in them, to make compact right-angle connectors.
Here's one with a 2.5mm TRRS plug, before the final assembly of the shell (it gets filled with Gorilla Glue, and then the strain relief is pushed over the threads).
Nov 20, 2017 at 9:25 AM Post #25,039 of 75,134
Woo-hoo the 89cent per 100 foams that I ordered from AE just arrived.
Take that VE!
Perfect almost as porous as VE thin foam. It's so much that I even donated some to my friends. I sure hope they add more color in the future. I wouldn't mind paying more for color.
Nov 20, 2017 at 10:06 AM Post #25,040 of 75,134
Take that VE!
If we are wishing for things then if they charged an extra dollar or two for a softer foam I’d take that deal.
Nov 20, 2017 at 10:16 AM Post #25,041 of 75,134
So I decided to pull the trigger on a usb dac after some reading and weighing my options.
I went for the Hifime Sabre UAE23HD which is mostly a DAC but also has a small amp suitable for IEM’s/Earbuds, but you can add your own amp if you need more power.
It’s not a fancy looking DAC but you pay for the internals and apperantly it’s a great performer especially the newer revision.
I paid €75 (about €15 cheaper than dragonfly black). So it doesn’t break the bank and gives me a taste of what external DACs can do. Add to that the apple camera connection kit needed to connect the DAC and the price comes up to around €100/$115. Not too bad.
Oh and I also received my DIY graphene’s today. I will burn them in overnight before giving my impressions. Initial impressions are very good natural sound similar to the shozy signature. Looks awesome too (I got the clear version)
I’ll save the comparisons till the burn in.
Nov 20, 2017 at 10:58 AM Post #25,042 of 75,134
that price is excellent but overseas shipping will be kill the deal.
thanks for the technique btw..
From Wikipedia - Neutrik was founded in 1975, and headquartered in Schaan, Liechtenstein.
I suspect they sell worldwide - check for a distributor in your area.
Using their modified right-angle connectors does allow for really compact plugs, on earbuds & earphones.
Nov 20, 2017 at 11:28 AM Post #25,043 of 75,134
Nov 20, 2017 at 11:38 AM Post #25,044 of 75,134
I just realize the same seller of the black foam also have white and red color. The mentioned weight is same at 10 gram (not sure whole 100pcs as 10 gram?). Anybody tried it yet?
http://s.aliexpress.com/veQJVBVj
Nov 20, 2017 at 11:47 AM Post #25,045 of 75,134
this is what i'm using:
you can use it mmcx earbuds like the Svara L (i'm using this one), ourart ti7, **** PT15, Daik, Tonekings, etc
I've got that and the PT15 on the way. But it is "over ears" design cable. Can the PT15's be effectively be worn over ear?
Another interesting option:
AUGLAMOUR AG1-BT Wireless 4.0 Bluetooth Cable
You can use a bluetooth receiver such as the FiiO BTR1 (just one example — there are others). Then you can use your favorite earbud.
https://www.head-fi.org/threads/fiio-btr1-bluetooth-headphone-amplifier-aptx-discrete-dac.850675/
Thanks for pointing that out. Inexpensive. Small. Has a built in clip. "Bluetooth 4.2, supporting SBC, AAC, aptX, aptX low latency". Very interested in that!
Nov 20, 2017 at 12:07 PM Post #25,047 of 75,134
i didn't own the **** anymore to try them with the bluetooth, but from what i remember the ****'s cables have enough clearance that makes them able to be worn over ear comfortably
that auglamour is tempting, the promised 8 hour battery life and magnetic swappable cable system could make them a winner
Nov 20, 2017 at 1:05 PM Post #25,048 of 75,134
Yes they certainly do sell WW.
Nov 20, 2017 at 4:41 PM Post #25,050 of 75,134
