BloodyPenguin
- Aug 10, 2011
"Waits Patiently"....
I had the same problem with the paint on my pair of QFred (none of the other problems, though). I solved that by buying a small can of Humbrol enamel silver metallic paint (#11) for hobby models and a small paint brush for models. It was fortunately a perfect match and now it's impossible to tell what is original paint and what is added by me.
You should be able to find that paint in any hobby shop or online. Or some other brand that is silver metallic...
By the way, about the seal at the plug, you mean it is open? I think that is for a purpose. Another Head fier who bought both CampFred and QFred noticed that the same plug is used but the QFred's plug isn't "closed". Herry replied him that it is on purpose because of the cable used for QFred.
When I reported my problem to Herry he replied that he probably will only go with pre-colored housings from now on. He can create the most amazing sound in his earbuds, but the psysical finish isn't always perfect (for example the text on my CAX black started to come off).
http://www.head-fi.org/t/822327/diy-earbudsHello all
Looking forward to do any mod in some earbuds, I have thought to get some experience before and I have open one thread to talk about it, share our experiences, improvements, etc..
I hope you find it interesting and I invite to all of you to participate.
As starting point, what do you think that could produce a bigger modification in the sound, changing the cable, removing internal foams, removing grilles, modifying the housing...?
Your opinions in the thread...
http://www.head-fi.org/t/837455/earbuds-mods-the-thread
democracy is hereWell, I missed it, maybe new thread is redundant...
https://www.google.ru/search?q=Beatzen%E7%BA%AF%E9%9F%B3A4%E8%BF%9B%E9%98%B6%E7%89%88%E5%8F%91%E7%83%A7%E8%80%B3%E5%A1%9E%E5%BC%8F%E8%80%B3%E6%9C%BAMX760%E5%8E%9F%E8%A3%858H2%E9%AB%98%E8%A7%A3%E6%9E%90%E5%85%A8%E9%A2%91%E5%8A%A8%E5%9C%88&oq=Beatzen%E7%BA%AF%E9%9F%B3A4%E8%BF%9B%E9%98%B6%E7%89%88%E5%8F%91%E7%83%A7%E8%80%B3%E5%A1%9E%E5%BC%8F%E8%80%B3%E6%9C%BAMX760%E5%8E%9F%E8%A3%858H2%E9%AB%98%E8%A7%A3%E6%9E%90%E5%85%A8%E9%A2%91%E5%8A%A8%E5%9C%88&aqs=chrome..69i57.1380j0j4&client=chrome-mobile&sourceid=chrome-mobile&espv=1&ie=UTF-8BeatZen Earbuds? I've never heard of them.
www.aliexpress.com/item/2016-Original-New-BeatZen-A4-13MM-Moving-iron-headphones-for-iPhone-Samsung-LG-Wireless-Mobile-Earphone/32707871336.html
What are some amazing budget white earbuds? I was thinking of trying to paint them. I was going to ask if the Edifier 180 are okay, but that review above made me curious if it's true... plus the metal piece on the bud might ruin the painting beauty of what a stock white earbud would have.
you can buy white shells for dirt cheap and put any driver into them
