maguire
- Dec 28, 2007
OK thanks Twin, they looked bigger in the photo. Not long to go now mate & you will be forgetting all about those TK12's.....
. YES SIR!!!
Those other things in the pic are quite small, think Flare Audio R2 small....
TWIN
Apologize if my previous photo caused some confusion about the actual size of the kegs.
Top to bottom:
Sendiy M2
KZ ED3
DIY K3003
"Kegs"
As noted the fit is very comfortable and seal easily without the supports.
The M2s are also easy to get a good comfortable seal with a variety of tips.
The worst fitting ones (for me) in this bunch is the K3s, as they are pretty heavy and have a large nozzle diameter.
How does the Sendiy M2 stack up to the others? If good enough, they could be a potential hold me over in case I decide to go with the Trinity which wouldn't drop for a few months.
jant71 & JacKallen,
Will keep my SQ opinion of the M2s short, as don't want to hijack this thread.
The Sendiy M2s are the best sounding single DD earphones I've heard to date; including the original IE800s, Monster Golds, Miles Davis, Zircons, Joyroom 107, and all KZs.
They also sound better than the two DIY K3003s I have.
Check out my posts or 1clearhead posts about these in the Chinese IEM thread.
They are that good!
In which areas do they fall behind something like the Kegs?
Woah there, why would the new A2 be better than the A3?![]()
Then, as I said, why would the A3 come out at $168 and the A2-II be still under $100 as reported by Paul. They can't not realize how good it is so they aren't gonna leave money on the table just to be nice. They are in business. If better it would pretty close to the $150 mark.
Now if you want to say they could be close and deemed a better value since they one list listed at $168 and one at $95. I'd say there is actually a pretty good chance at that happening. But them being consensus better is very very doubtful. You don't essentially sabotage your flagship so soon after release. Not when you are a small outfit with less earphones than you can count on one hand.
If it does turn out that way then I'm glad I skipped the A3.![]()
