Eagle question: how to use eagle with cam machine?
Dec 5, 2004 at 11:15 PM Thread Starter Post #1 of 5
nleahcim
Hi - so I'd like to make a couple PCBs that I have drawn up in Eagle. I have access to a large number of CNC milling machines. I was told that they will mill out anything for me, as long as I can get them "g-code" for the board. Does anybody have any idea how to do this? I looked at the cam processor in eagle, and the help section for the cam processor, but I couldn't find g-code listed as an output format. Can anybody lend me some assistance? Thanks!
Dec 5, 2004 at 11:56 PM Post #2 of 5
I would imagine you'll need them in Gerber format; go to:
File > CAM Processor
File > Open > <EAGLE FOLDER>\cam\gerber.cam
Process Job > Ignore all messages.
Then for the drilling files
File > Open > <EAGLE FOLDER>\cam\excellon.cam
The files these generate you should give to your friends at the machine shop, and they should be sufficient to process the job
g
Dec 6, 2004 at 12:53 AM Post #3 of 5
g
A-ha! So Gerber is G-code? That would be awesome if it were really this easy.
Dec 6, 2004 at 2:46 PM Post #5 of 5
Well, I hope it is. All board houses accept Gerber as their preferred format
g
I've never looked but do the standard Gerber files include depth as well as X and Y?
If you are milling out the copper instead of creating a photo mask do you need the depth too? Or is that something that would be manually entered on the milling machine?
Just curious. I do know that many of the small run quick turn boards are milled and not photo etched.
