jsmiller58
Android version of Tweak9038 is on the Google app store. I don't know about iOS.Just received my 9038D. How do I get the Tweak app? Is it on the App store?
For my E1DA PowerDAC V2 i use Hptoy... Beautiful app... Just turn on Bluetooth after install and EnjoyJust received my 9038D. How do I get the Tweak app? Is it on the App store?
Just got the cable and 9038D to verify it's 8 mm from the inner limit of the USB-C connector to the inner limit of the section that connects to a device. Also consider the 9038D will cut into that a little since it isn't flush with the j-cable. With the E1DA logo facing away from the phone this gap is reduced by 3mm (to 5mm), with the logo facing towards the phone the gap is reduced by 1mm (to 7mm). Also, I am noticing that TRRS plugs need to be slightly loose for the sound to work with my 9038D, not sure what that's about. I ordered a TRRS female to TRS male adapter to see if that takes care of the problem, but normally I can connect my TRRS headphones to a TRS/headphone jack without any issues.Could you please measure the gap between the two USB jacks i.e. the space for the phone? Would be great if I could use it with the protective jacket of my Xiaomi Redmi phone. I mean this J-adapter:
https://nl.aliexpress.com/item/1005001476774066.html?spm=a2g0o.cart.0.0.4d383c00Gzl1Nd&mp=1
The seller just told me the distance/gap is 8 mm. Is this the space for the phone or the space between the connectors? Thanks.
Thanks a lot. What's TRRS/TRS?Also, I am noticing that TRRS plugs need to be slightly loose for the sound to work with my 9038D, not sure what that's about. I ordered a TRRS female to TRS male adapter to see if that takes care of the problem, but normally I can connect my TRRS headphones to a TRS/headphone jack without any issues.
It stands for Tip, Ring, Sleeve or in the case of TRRS Tip, Ring, Ring, Sleeve.Thanks a lot. What's TRRS/TRS?
So when I only use normal three connector mini plugs I should be OK? Guess so ...It stands for Tip, Ring, Sleeve or in the case of TRRS Tip, Ring, Ring, Sleeve.
The first one is for 'unbalanced' cables and has three connections, which means that the left and right channels share a common earth or ground connection. In TRRS, there are four conductors, so each channel has its own, independent + and - signal, generally considered to cut down on crosstalk (interference between one channel and the other) as well as allowing balanced amplifies to deliver higher voltage to each channel.
Cables with microphones in also have 4 connectors but they are not to be confused with balanced (TRRS) cables with no microphone.
For the 9038D-yes. For the 9038S definitely notSo when I only use normal three connector mini plugs I should be OK? Guess so ...
as far as I know you *need* the android app for that.but need to know how I can change filters or clock rate on my Windows 10 laptop. Is there a way to do this?
You can change the filter using the flashable firmware, I am not sure about the clock.I have the 9038D. Love it btw. I have the Tweak app, paid version but need to know how I can change filters or clock rate on my Windows 10 laptop. Is there a way to do this?
or you can connect it to your android , choose the filter you want via app. then disconnect it and reconnect to your PC.You can change the filter using the flashable firmware, I am not sure about the clock.
