King CATalyst
Do the dekoni elite hybrid pads for thx-00 on massdrop fit emu-teaks? (I assume they do but just making sure) and does anyone know if they change the sound? Also how hard are they to swap pads?
Just purchased a pair! Now i just need to know where/how i buy the rosewood and ebony cups?
I see you had the Atticus? How does the Emu Teak compare? I've been thinking of getting either Atticus or Eikon. I'm hoping to test them out at CanJam NYC 2019.
Any idea how I could get my hands on a pair of teak cups? I bought my pair used but they had the Palo Santo cups on them.
Good morning everyone.
Does anyone have aftermarket pads that have a better overall seal?
Also, I'm looking for a blanced XLR Cable. Does anyone have an aftermarket cable to suggest?
James
Periapt makes a nice balanced cable. I believe its the type 2 cable dual 2.5 mm XLR.
If you've been reading carefully, you've probably noticed that I've basically said that the Atticus has more bass, more mids, and more treble. And, that is sort of correct. It definitely has more bass, but otherwise this perception of 'more' seems to be more accurately expressed as this: the Atticus has a much more intense, immediate, vibrant, dynamic sound with greater detail, while the Teak has a softer, more relaxed, more even sound with a serious low-end kick. With the Atticus, I find myself missing the sub-bass presence of the Teak. With the Teak, I find myself wanting a bit more dynamism (except in the bass). I think both are incredibly worthy headphones, with the Teak representing an absolutely expert tuning that is very easy to sink into and the Atticus offering a significant improvement in technical prowess, despite both being well-tuned and capable.
Thanks for the comparison. I'm off to CanJam this weekend to see if the Atticus or Eikon (or some other closed headphone) can offer the increased dynamism I'm also looking for over the Teaks. Slightly more expansive soundstage would also be nice, although that might be asking too much in a closed headphone.
Do you find the Atticus has excessive woody-related coloration of the sound compared to the Teaks? Are the timbres of instruments generally pretty accurate to your ears? I'm going to be most curious how the additional sub-bass extension of the Eikon compares to the Teaks. I suspect if the Atticus leaves one wanting more in the sub-bass then the Eikon might leave one wanting more slam in the mid-bass. I shall see.
