The build quality of the Denons D5200 or D7200 excels the E-MUs, that’s what I’ve read in multiple posts also. Maybe compared to the relatively low price of the D7200 now and even cheaper (475€) than the E-MUs right now, I wonder if the E-MUs are worth the +150€ for shipping and tax included
Someone who does not know both listeners will not notice the difference in sound.
I'm referring to the older design of both headphones compared to the current Denon series.
But someone who knows them will go for the Fostex or Emu.
I didn't notice it at first, but I did later when I compared them, and that's how it stayed.
The workmanship of the current Denon series is indeed remarkable, I would wish for that on the old series if I am honest.
Apart from that, the Emu has the advantage that you can change the cups and pads and bring them as far as you want.
The current Denon series can't do that.
So if you buy the current Denon series then it is as it is.
You can only have a little influence on the amplifier, but nothing more.
I would only want to listen to the D7200 on a fairly neutral amplifier, then the bass response will be better. That it bleeds less into the mids. But this is purely my subjective opinion.
Others see it differently, as we have seen, without wanting to make a science out of it.
I found the D5200 breathtakingly good on the Macintosh. Everything fit where I thought wow, the amplifier and the headphones, that's all you need.
The only thing is that the amplifier costs a lot, unfortunately.
I listened to it on another amplifier and all I could think was help. Nothing fit anymore, no bass, much too sharp and so on.
