tman1
- Jan 11, 2007
In fact I am now fairly convinced that this is the case. I have somewhat mild tinnitus that gets better and worse depending on whether I've been recently exposed to concerts, listening to headphones, etc. I had a pair of Soundmagic PL50s (armature) a while back and didn't notice it too much, then when one earpiece stopped working I switched to my backup dynamic Koss IEMs and noticed the tinnitus got worse after listening. I figured this may have been because they were more harsh/trebley.
Then I got some MEE A151s (armature), and wasn't crazy about them due to the lack of bass impact, so I got some Brainwavz M2 dynamics. I went back to the A151s for a recent cross-country flight since they isolate a little better and I kept using them for a while and didn't notice the tinnitus much. Then an earpiece on THOSE starting going bad so I recently switched back to the M2s and IMMEDIATELY noticed that the tinnitus got obviously worse after listening.
So it has happened twice now. The M2s are fairly "dark" phones so I know it is not due to excess treble. Some may say that the M2s don't isolate quite as well as the A151s and so I am probably turning them up louder and THAT is causing the problem, but I don't think so. The difference in isolation is not that great and I have been careful to keep the volume at reasonable levels, lower than I would like, and my ears are still ringing as I type this in my office. I used the A151s on a plane all the way across country and don't remember thinking about the tinnitus and now with the M2s it is much worse after only a short listening time.
Has anyone else noticed this? I am now guessing that the more dynamic (in terms of impact, not physical design) phones pound the air against the eardrums harder, and that the lack of dynamics from the armatures, while not perfect for rock, are actually better for your ears for this reason.
I need to send the A151s back for repair but I think once I get them back I will stick with armatures even though I prefer a more dynamic sound. I am a little leery of using the M2s at all now since the tinnitus is definitely noticeably worse, even hours after listening.
Thoughts????
I did a search and found one example where someone else had a similar experience, so I am not the only one:
Quote: Originally Posted by anodyne
I have a pair of Cresyn C750 buds. They had an accident and I can now with my own eyes see the little rectangular unit the Korean makers of this odd-ish brand call a "micro-max transducer" – which I believe is what is more commonly known as an armature driver. I liked the sound quality the gave me for about €35, but what I liked most was the listening comfort. I have slight tinnitus, but I could use these for hours on end without any discomfort. I'm guessing that there's something about the armature->acoustic filter design that is less violent on the eardrums than a traditional driver. The distributor seems to have to dropped Cresyn here in Sweden, there are a few on sale but I'd like to look for more options and maybe a small step up. I want something that I can carry daily without worrying too much about snags. Maybe somewhere in the €50-70 range. Any ideas?
Thoughts????
