after some months of service my Dynahi PSU died too. I switched the amp on to let it warm up and had it on just a few minutes when something inside the case exploded, creating a small cloud rising through the ventilated top panel and blowing the fuse.
First I suspected a tantalum cap had failed short, but when I opened the case I had to realize that the right OPA541 was blown, exactly like Juergen's. The opamp was first mounted on the angled bracket and then soldered down, so I can exclude poor heat dissipation to be the reason. Additionally, the failure happened a few minutes after power up, so it can't be overheating either (I'm using a 30VAC Avel-Lindberg transformer).
For some reason I don't want to solder in a $16 replacement without changing something else and see it pop like the first one.
I noticed significant hum (dependend on the volume pot setting) through my cans shortly before the PSU blew. Therefore I suspect the PSU had locked up during power up or oscillated, maybe due to excessive capacitive load.
Unless anybody can supply a better suggestion (I won't rebuild the whole PSU on another pcb) I'm going to remove the 4700uF caps from the outputs of the opamps before I replace the OPA541. I'm going to repair the PSU next weekend and will keep you informed how it turned out.
