NRD
- May 13, 2007
I've finished building the Dynahi and got it powered up but need help with bias and dc offset. I read AMB's comments in the build thread where he mentioned using two trim pots per board, but I also came across SFT's comments of being able to use one. Here is the thing, I got the DC offset down from -100mv in the left channel to ~1mv and from -75mv in the right channel to ~1mv (all this with no servo installed) BUT the offset seems to oscillate/vary (especially in the left channel) anywhere from -8mv to +4mv even after the thing has been on for 10min.
Q1) That said, would using two pots per board keep things more stable? If so, what value across pins 2 and 3 of the pots should I start with (I don't know if I should start at max pot resistance in each pot or min)? I'd prefer to try to get away with using one pot, since I'd have to go out an buy two more, but if it really is a more stable config, I'd rather go that route.
Q2) I get some hum depending on the position the volume pot is at. If it is at 50% it is dead silent (with 16ohm earphones too!), at 100% (i.e. max volume)dead silent until I plug my ipod into the RCA jacks then I get hum, at 0% I get slight hum regardless of the use of RCA's. Any suggestions? Ground scheme is as follows: all grounds tie together at one point at the chassis, but the RCA jacks themselves are grounded to the chassis on the back chassis panel, from which they connect to the board's "signal input" ground node. Also, fyi to prevent pulling any noise, I am not using the power outlet ground
