DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
Jul 27, 2024 at 11:17 AM Post #10,381 of 10,506
Yeah I never had any issues with the X edition, but I don't recall ever having problems with the standard DX300/DX320 either.
The regular version do indeed get annoying some times. Especially when you are trying to slip it into the pocket and with the case covered on. The buttons are too easily clicked on and be annoying. Some annoyances with 320Max Ti as well. But just so long as I know it is there and avoid it, it is fine. Just like all things in life, you know it, you prevent it :)
Aug 7, 2024 at 8:44 PM Post #10,388 of 10,506
Hi. I have a crazy question. Has anyone tried the smule karaoke app with a dx320? I have a headset with a trss output. I installed the smule app on my dx320. The app crashes when I try to record audio. Has anyone experienced this? Unfortunately, I experience audio delay on smule on non-jack inputs. I don't have a phone with a jack input either. The only android device I have with a 3.5mm input is the dx320.
Aug 22, 2024 at 4:37 PM Post #10,390 of 10,506
I know that in this topic you recommended chargers for dx320. My Baseus charger just broke and I would like to buy a good one. They will ask for a company that makes such chargers.
Without knowing where you are located in the world and what products are available to you, I can only recommend charging technology and specifications. For DX320 I would go with a minimum of 35W power if it will only be used for your DX320. As a technology, GAN chargers run cooler and more efficiently. As for charging spec DX320 supports QC 3.0 and PD 3.0.
Aug 27, 2024 at 5:18 AM Post #10,391 of 10,506
How’s dx320 in 2024? I’m ac tu ally using a dx260 thinking of upgrading eventually, I’m looking for a bigger screen since I’m always discovering new music.
Can it hold against hiby rs8 or ak sp3000?
Thanks
Aug 27, 2024 at 8:38 AM Post #10,392 of 10,506
Thanks
I just picked up a used DX320 Edition X. I have owned the RS8 previously. My genres of music are mostly string quartet and chamber music. The RS8 is an excellent DAP with good all around smooth sound. I do prefer the DX320 due to the sound being on par with the RS8 but also the optional amp modules providing the sensation of getting several DAPS in one. The UI and screen of the DX320 is excellent also. Bluetooth and WIFI connectivity have no issues, It is my end game (until a replacement for the DX320 comes out) :)
Aug 27, 2024 at 8:43 AM Post #10,393 of 10,506
Thanks, I think new dx3xx is close
Aug 27, 2024 at 8:46 AM Post #10,394 of 10,506
Thanks
Unfortunately I haven't listened to rs8 or sp3000 but I have listened to sp2000. I prefer dx320. Dx320 still feels very smooth and fast in 2024. Android 11 is available on the device. Almost all applications work smoothly and fast. Sound quality is excellent. Sound color is very neutral thanks to the rohm dac chip. It is not as shrill and cold as fiio. It is not as warm as astell kern. It is in between. Dx320 is very powerful. Hifimsn sundara and sennheiser hd800s can drive hd820.
Aug 27, 2024 at 9:18 AM Post #10,395 of 10,506
Thanks
I think dx320 will give satisfaction in terms of SQ for a very long time. However, when answering such a question I always recommend listening before final decision - because although it is good, you do not have to like it due to your preferences or synergy aspect.
