DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
May 3, 2018 at 6:38 PM Post #13,261 of 22,021
Is there a case other than default or Chinese/Korean ones on eBay? I actually want a rubber or silicone type case like the DX90 had.
I'm not aware of a silicon case for the DX200. There are a few other leather cases that you can buy though.
Miter - https://www.amazon.com/MITER-Leather-Case-Patented-Protector/dp/B06XFYPC2F
A6 - https://www.aliexpress.com/item/A6-...eather-Case-For-IBASSO-DX200/32811825054.html
Valentinum (You can get many other styles too) - https://www.etsy.com/listing/575781954/ibasso-dx-200-leather-case?ref=shop_home_active_38
May 3, 2018 at 7:39 PM Post #13,265 of 22,021
Here are some pictures of the blue Valentinum leather case for DX200.
May 3, 2018 at 10:26 PM Post #13,267 of 22,021
That is a nice looking case actually. Would be great if somehow a flap door (magnetic or Velcro) was implemented to protect/conceal the SD slot.
May 4, 2018 at 5:18 AM Post #13,269 of 22,021
May 4, 2018 at 8:00 AM Post #13,273 of 22,021
May 4, 2018 at 8:02 AM Post #13,274 of 22,021
4S is much warmer than 4. 4 has better treble extension.
Warmer as in negative way?I'd love some meaty bass but somehow tamed upper highe. Does the amp5 dit this description ?
May 4, 2018 at 8:22 AM Post #13,275 of 22,021
Not in negative way. It does have meaty bass and euphonic vocal and tamed treble as you like. But I lean towards reference sound so I like AMP4 a little bit more. but having choices for matching is good. :)
I don't have AMP5 btw.
