Nope i sadly do not have amp 3 or amp4.
Only heard amp1, amp5 and amp4s! Too many amps yet only one dx200...
What I need is one Master AMP.
One AMP to rule them all
One AMP to find them.
One AMP to bring them all
And in the darkness bind them
Lol how are you managing the back and forth?
AMP3 vs AMP5 on DX200 - quick impressions.
Volume matched roughly by ear (AMP5 required about 6 clicks more)
IEM’s: iBasso IT03 (big soundstage, detail and clarity, DD providing substantial but accurate low end, slightly recessed mids).
Cable: iBasso CB13
Songs used:
‘Ophelia’ by Madeleine Peyroux
‘All Over You’ by Live
‘Little Sister’ by Jewel
‘Art of War’ by Anberlin
‘Motion Picture Scarecrow’ by Hobotalk (not mentioned below for brevity, but I preferred the AMP3 on this, although it was close).
AMP5:
‘Ophelia’:
Feeling of softness.
More intimate (smaller soundstage?)
I notice some details pop out a bit more (soft taps as she bridges her fingers on the guitar top, or bumps a knuckle against it)
More musical, analogue, organic
Vocal stands out, rich timbre
Sounds seem thicker and with more weight and presence
Ophelia 01:23 - 01:28 guitar fingerpicking (right of centre): first part 01:23-01:25) is barely audible - placement not separated enough from the vocals and percussion, so it gets a bit buried.
The second part (01:26-01:28) is fine though.
‘All Over You’:
More warm, more organic, less sharp
Vocal richer
Guitar richer, thicker, more texture
More musical, cohesive, engaging
I’m feeling the music more
Slightly more bass weight and low end presence
Less feeling of openness and spaciousness than on AMP3
‘Little Sister’ by Jewel:
Thickness and weight of guitar picking
Closed in, congested, lost the wide, spacious feeling of AMP3 (even with the IT03!)
Everything sounds a bit muted and homogeneous in comparison.
‘Art of War’:
More cohesive and musical. The strong feeling engagement comes from this. 00:11 - 00:18 the bassline, percussion and keyboard percussion effects all gel together in such a way that they are greater than the sum of their parts and the overall feeling is incredibly engaging. The bass is perhaps more
AMP3:
‘Ophelia’:
More fatiguing
More sharp and clear
More neutral (in comparison to AMP5)
Greater feeling of separation?
Greater height in the soundstage
Ophelia 01:23 - 01:28 guitar fingerpicking (right of centre): first part 01:23-01:25) is more audible and distinct, although it’s somewhat buried in the song itself.
‘All Over You’:
Cymbals have a musical ringing quality.
Energy, clarity, dynamic sound
Low end there, but not emphasised and not very powerful
Big soundstage
Vocals a bit thin.
A bit sharp and fatiguing
‘Little Sister’:
(Only acoustic fingerpicked guitar and female vocal in this song, which was recorded live. Nothing else in it.)
Breathtaking clarity, soundstage size, purity.
Each note sings.
No sharpness or fatigue.
‘Art of War’:
I notice that compared with AMP5, the keyboard percussion effects lack weight and presence here, which stops them binding together the other percussion and the bassline.
The bass has more clarity and definition; although I think the AMP5 has a bit more weight or emphasis in the low end overall, the way that AMP3 presents the bass here actually seems to make it stand out more and make it more effective; I assume this is related to the fact that the synthetic percussion lacks the equal prominence afforded it with the AMP5?
Conclusion:
Different songs sound better with different AMP units.
This is not entirely unexpected
I don’t know, but it seem you are saying amp5 is more musical and smoother than amp 3. While someone else said amp4s is even more musical than amp5....then this amp4s is different than the Amp4 (none S)
Mine was supposed to deliver by Monday, but I called dhl to schedule Saturday. But the driver forgot to take the package so they had to special deliver on Sunday(today) hahaha.
Yes, but I don't think it's Aptx. I listen to Vmoda 2's and B&w P7 on way to work all of the time. 1 1/2 hr commute . But the DX200 makes it bearableDoes the DX200 have the necessary hardware to receive BT?
Cable: iBasso CB13
Songs used:
AMP5:
‘Ophelia’:
‘All Over You’:
Vocal richer
‘Art of War’:
AMP3:
‘Ophelia’:
More fatiguing
‘All Over You’:
Big soundstage
Vocals a bit thin.
‘Little Sister’:
Each note sings.
‘Art of War’:
Conclusion:
I heard the same even though not the same musics or songs. Amp3 is more forward with dynamic sound and big soundstage whereas amp5 is more softer, sweeter but less soundstage and non fatigue. Let see amp4s sounds differently after receiving it tomorrow. Stay tuned!
Btw, have anybody noticed after installing the new 2.9.198 L1 FW the charging time is getting longer and the DX200 gets cooler!
If you feel such a way, I recommend you to do discharge (until it turns off) and then charge overnight at least once. It is important to charge DX200 being turned on. Because you couldn't turn it on when the battery was discharged, put it on charger for 15 minutes, turn on and leave on the charger. This way Android's kernel will adopt the new charging parameters faster. It will adopt them in a week of usual use anyway.Btw, have anybody noticed after installing the new 2.9.198 L1 FW the charging time is getting longer
On the contrary, with 2.8.198L1 the battery can't be overcharged.Overcharging the battery with less current?
Overcharging the battery with less current? This is not good for the battery ... (( There are specialists?
