- May 7, 2017
As long as the faceplate hasn't fallen off, this is a very good thing
Or your ears will fall off!
It makes my Fourté sound freakishly open lol
Does clean install firmware really eliminate bugs? My friend’s DX200 did clean install to eliminate popping and skipping issues as suggested but no luck. Doing clean install is a bit take effort for me as i dont have any windows computer.
Other question, what is the benefits having lurker fw installed?
Thank you!
Junk? Because of a learning curve. Sounds like you are frustrated the DX200 is not junk.Hi all first post here so be kind so waited in all day for my IBASSO DX200 to be delivered only to find out its pretty much junk
Issues:
Cannot get it to connect to my PC via USB(unknown device) just get device not recognised over and over also tried looking for a driver ...nothing (contacted the seller) "advancedmp3s" who claim there are drivers on the IBasso site but nothing... so just downloaded the latest firmware v2.8.198 put it as instructed unzipped onto sd card but now i get "verifying failed, please check you package"
never had such problems with a DAP before FIIO and Questyle just work straight out the box...not happy with this what so ever
I agree with @jamato8. There is just a little learning curve to it. Once you figure it out It's so worth it.Hi all first post here so be kind so waited in all day for my IBASSO DX200 to be delivered only to find out its pretty much junk
Issues:
Are you using the included USB cable?swiping from the top only ever gives these options "wifi... bluetooth.. airplane.. portrait...Cast"
i have also looked numerous times for the usb driver download the only one is the USB/DAC one(which i dont require as i dont want to use it that way)
learning curve things should just work... imagine if you purchased a new car and it was like this "you cant drive it yet because we have not fitted any tyres"
I don't have my DX200 with me otherwise I would try it. Maybe swipe down twice. Does anyone else have any ideas?yes its the only why i have got
When you download the FW you unzip it and use that new zip file for the update. The instructions are all there and even on the first page of this thread. Also there is a driver on the iBasso site, just look for it under downloads. I have FiiO and there have been some issues but I learned (the learning curve) and got through it.
Try swiping from the top and select USB file transfer on the DX200. Maybe someone else can confirm this.
If you still have issues Paul at iBasso is VERY helpful.
Good luck!!
I had a defective unit bought from B&H with ghost swipe screen and felt so frustrated at that time then decided to buy directly from ibasso. Paul was very helpful and rushed to send new DX200 to me the fastest way. Then I struggled with installing Lurker0 FW but Mr. Lurker was also very helpful shown me step by step until I got it. Now I am a happy owner! I have learned a lesson of calming down myself and especially be patient in any situation or hard way!
You have to take the clock off of Auto date and time. Then tap on the am pm and it will switch back and forth. Or you can use the wifi for network time. I set mine manually as I prefer that method.thanks gc335 for trying to help me out
the clock seems to be stuck on am as well nothing in the settings will allow me to take it to pm or past midday so i think there may be something seriously wrong
