DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
772 773 774 775 776 777 778 779 780 781
783 784 785 786 787 788 789 790 791 792
  1. guille
    Hi
    First of all forgive if this issue is already in discussion, I read the entire forum
    My problem is with Neutron Player (ibasso firmware), in a moment while I listen to a tracklist it falls neutron and I have to restart it, what should I configure so that it does not happen ?, I have tried many things. This always happens
    Thanks so much, this is a great forum
    Guille from Chile
  2. Lurker0
    This usually means, Neutron thinks its trial period has expired, and license wasn't purchased. Because you use the stock firmware, purchasing via Play Market is not your choice. The recent update (March, 4) should be more user friendly with expired trial period and licensing, but I don't know more details.
    So, you'd better contact the developer to find out what to do.
    mrmoto050 likes this.
  3. guille
    Thanks so much for the answer
    I bought Neutron app (apk), then I read in the forum of Neutron and there is an optimized version for Ibasso dx200, I downloaded that version that is the one that I currently use, for that does not pay, that would be the reason? If I used the payment method, would there be problems ?, but I do not know if that version is optimized for Ibasso dx200. In the forum I started a topic with this problem but until today I have no answer, I will contact Neutron directly.
    Thanks!!!
  4. Lurker0
    If you have purchased it via Play Market on another device, which has the Market pre-installed, you may try to install my firmware, and then logon into Play Market and install it from there. Then it will work for sure, and you'll no doubt have the version optimized for DX200.
    mrmoto050 and Dobrescu George like this.
  5. icefalkon
    Thanks for that list! I didn't know about all of those guys. I don't think I'm going to bother with getting a silver balanced cable for my Angies now though...since the IT04's are kicking so much butt it's not worth it. However...once the LCD's get here....and I think they're out for delivery...with the balanced Litz cable and AMP4...oh boy.
    My wife won't hear from me for days...lol
    And she'll be ok with that! lol
    KEV G, mrmoto050 and kubig123 like this.
  6. mrmoto050
    Deleted text -irrelevant
    Correct me if I am wrong, but isn't there a custom Neutron player expressly for DX200? I think that is what I am using along with your custom FW.
  7. Lurker0
    No. It detects DX200 at run time.
    But there are many different builds, optimized for different hardware. Many of them may run on DX200, but ARM64 build is the best choice.
  8. mrmoto050
    I have a question about the AMP's. I was thinking about getting the AMP5 but I already own the AMP2 which I really like with my LCD2's. For those that also own more than one AMP , do you think it will be worth the upgrade?
    Thank you in advance.
  9. pfurey89
    What AMP module will hit the hardest in the subbass and midbass region on this?
  10. alan_g
    omg ive just bought one of these delivery in a few days... I may be back with questions
    icefalkon likes this.
  11. kubig123
    If somebody is interested in this cable send me a PM.
  12. guille
    I purchase the app here http://neutronmp.com/buy.html (apk directly not google play cause my only android product is ibasso dx200) but in the forum recommend this version NeutronMP_ARM64_USB_NO_DEF.apk that download free here http://neutronmp.com/downloads/category/1-generic-android.html
    I will install the version tha I purchase, if I have the same problems, I'll try whit your firmware
    Thnaks so much bro for the help
    Guille
  13. icefalkon
    What's wrong with the cable Ku? Or did you just upgrade? :wink:
  14. icefalkon
    IMG_0051.JPG IMG_0052.JPG IMG_0053.JPG IMG_0054.JPG IMG_0055.JPG IMG_0056.JPG IMG_0058.JPG Look at what just came in boys! Brand new LCD2's from Audeze! I sent mine in for repair and they sent me back an early birthday present!
  15. Dobrescu George
    One really needs to have one in his hands to understand the greatness of Audeze XD
    I like that they really make their boxes durable. Down to the very definition of that :)
