DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
771 772 773 774 775 776 777 778 779 780
782 783 784 785 786 787 788 789 790 791
  1. jamato8 Contributor
    I would get the CB12 or CB13 from iBAsso as they are both really good cables. The CB12 will get you into balanced for $89 and the cable is flexible and pretty much no microphonics. But I don't remember if the Angies use 2 pin or MMCX and the CB cables are MMCX. I also purchased a pair of very high quality 2 pin to MMCX that are really short and then make any of my 2 pin IEM's MMCX compatible.
  2. dougi555
    Ibasso's own website has it in the discontinued section, not even available for purchase. I tried...
  3. jamato8 Contributor
    True but iBasso has stated it will be going back into production.
  4. alan_g
    4 pin connectors on the angie if I remember correctly, not usedthem in a while
  5. jamato8 Contributor
    I see. What a pain. I now remember a cable manufacturer emailing me and saying they were a mess to make cables for and the connector was what made it difficult.
  6. mrmoto050
    Yes I believe they are proprietary to JH Audio, but not sure. I have the Rosies same type connector.I believe they are made by Moon.
  7. alan_g
    yes moon audio made the cables
  8. kubig123
    Cables for JH Audio are available from most cable company, they are just more expensive compared to cables for other connectors since they require 8 wire, but Effect Audio, PW Audio, Whiplash offer cables for this specific JH connector.
  9. singleended5863
    Yes it is 4 pins connector
  10. icefalkon
    My cable guy won't do them, nor will many cable manufacturers because of the 8 wire braid.
    Sorry brother, those three and maybe one or two others will do it, but it is not common. That is the only thing I don't like about my Angies, is that ridiculous connector.
  11. icefalkon
    My DX200 and my new balanced Litz cable are ready for my Audeze LCD's....where are you?? lol
    fuhransahis and Dobrescu George like this.
  12. jamato8 Contributor
    I would give them a polite call and inquire.
    Dobrescu George likes this.
  13. icefalkon
    I was going to, but when they received my old ones and called and said not to worry we're sending you a complete brand new pair I didn't want to rock the boat and find out that I was dreaming the whole thing lol!
  14. kubig123
    I agree, the connector they use limits the cables you can use it.
    But there are quite few companies that makes cable for JH Audio, in addition to the 3 I mentioned before:
    • Han Sound
    • Nocturnal Audio
    • Beat Audio Lab
    • Null Audio
    • Double Helix
    • Labkable
    These are ones I'm aware of, but I'm sure there are more around.
    icefalkon likes this.
  15. mrmoto050
    Oh
    Are you going to like that! I'm pushing mine with AMP2, don't have balanced for LCD2 yet.
