- Oct 6, 2013
Guys foxtrot is very clearly a troll. Please ignore.
Foxtroll?
So I finally got my Moon audio black dragon balanced cables for the JH Roxanne II. I had been using the SE cable for about a month since I couldn't find the original JH balanced cables.
I had to use the SE cable on Amp1. Switched to balanced cables and Amp3 today.
BIG BIG BIG difference in soundstage. Highs seem to be a lot more pronounced and in your face. Lows are a bit calmer. I'm very impressed overall.
The unit also runs cooler compared to amp1 where it heated up fast. Perhaps this is due to me using volume at 70 on amp3 balanced vs. 80 on amp1 SE.
Works fine for me, but you have to install lurker firmware first.Thinking about a Dx200 for Hi-Res streaming and offline import purposes. Anyone using one for Tidal and/or QOBUZ?
I'm very close to pulling the trigger on the dx200 to replace my ak100ii, will I be best to get the balanced cable for my angies or stick with the single ended one, would the change be a significant one?
From what I read on this thread amp4 and amp5 are the best amp available.
If you don’t own any balance cable than I would suggest to go with the amp 5.
The amp4 would require further investments in cables.
