DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
766 767 768 769 770 771 772 773 774 775
777 778 779 780 781 782 783 784 785 786
  1. KEV G
    I know how that feels, your not alone in your suffering :stuck_out_tongue_winking_eye:
  2. Stealer
    @drmacman
    So with the new Nichon jack did it solved the problem?
    My Sony kimber cable use with Wm1a do not see this problem except for amp4 module.
  3. ExpatinJapan
    Amp 4 with ALO Audio SXC-8 is certainly delicious
  4. fuhransahis
    Well that's just the cutest burger I've ever seen!
    XforceVesa and ExpatinJapan like this.
  5. drmacman
    @Stealer
    Yes:grin:
    If you can solder and often lose something small (like me!) , replacing jack is really good way to solve your problem.
    ...But the warranty will be void, and if you do this, plz do at your own risk.
  6. icefalkon
    LOL Love the burger with a happy face!!
  7. Retropsych
    I'm not getting the USB mass storage drop down options anymore. I am using Windows 10 64 and have installed the Rockchip software.
    It's been a while as I've usually removed the micro SD card and used a card reader to modify the music files.
    I've tried the original supplied cable and 2 USB-Type C cables, which all otherwise charge the DX200 but won't allow it to sync.
    However I can access the micro SD card (but not the on board memory) when Windows shows the "Decide what action occurs with this device" or similar pop up notification.
  8. Mahalarp
    This place should be the cafe in Nakano Broadway LoL :D
    ExpatinJapan likes this.
  9. vovanopulo
    Guys, I've got a strange question. I want to listen to DX200 through Fostex TH900-2
    I'm thinking right now of two options:
    1) AMP4 + CA02 + 2,5TRRS->XLR4PIN adapter + XLR balanced cable to TH900-2
    2) AMP5 + stock SE cable to TH900-2
    never mind the expenses, my main question is - should I strive staying balanced with AMP4 or get AMP5 and be SE?
    Many thanks in advance!
  10. fuhransahis
    I'd recommend buying a custom cable for the TH900 instead of the string of 35 adapters.
    Edit:
    Try Forza, they're in Europe.
    https://forzaaudioworks.com/
    kubig123 likes this.
  11. ExpatinJapan
    Thats the place :)
  12. vovanopulo
    Alright, what you say makes sense and simplifies the question of connecting DX200 to TH900-2 to:
    1) AMP4 with balanced aftermarket cable
    2) AMP5 with stock SE cable
  13. claidler
    UK/EU iBasso customers: we have had confirmation that there has been a delay in the manufacturing of the AMP4, but we have been provided a stock arrival date of April 7th.
  14. immortalsoul
    Hey guys, I bought me an Ibasso DX200, and I like what I hear. From this thread, everyone is stating that AMP4 is a great amp that takes the sound to a different level. Is there any chance for Ibasso to create an AMP6 that have the same AMM4 sound but with the usual 3.5 mm. I do not have any cables terminated in 4.4, and most of my headphones are not balanced. Thank you for your answer
  15. singleended5863
    Get yourself the amp5 only for SE. I heard it is an excellent amp to pair with DX200 second to balanced 4.4. I got one on the way from Penon Audio.
