DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
755 756 757 758 759 760 761 762 763 764
766 767 768 769 770 771 772 773 774 775
  1. SoLost
    Sorry I no longer have the DX200.
  2. singleended5863
    I am done installing the Lurker for new FW updating and all needed streaming music apps.
    Now I got other problems like popping sounds after an end and begin of the song. Most of the time the screen frozen and I could not move things or change songs...Are there ways to fix these problems? Thank you.
  3. icefalkon
    Do a factory reset. That should fix everything.
  4. singleended5863
    If I do a factory reset would it loose everything especially the FW update?
  5. icefalkon
    No, you're supposed to do a Fac Reset after updating the firmware. You won't lose anything on your microSD card and you won't lose the update.
  6. singleended5863
    I did install the streaming music apps and downloading some songs to listen offline since they are stored in internal memory of DX200. Would these are going to be erased too?
  7. icefalkon
    Um...I think so yes. But you can easily reinstall them.
  8. foxtrot
    Please explain. Why do we need "left" firmware, if they have worse sound quality? In order that would ruin the battery?
  9. singleended5863
    After installing the new FW (Lurker) and factory reset I found out the only streaming music app (NCT) causes the popping noise in the gap between songs even though DX200 has been done with twice factory reset. There is nothing could affect to the sound at all.
  10. icefalkon
    You don't "need" Lurkers firmware. You can install it if you want the Google Play Store. Lurker takes the stock firmware and makes it more efficient and adds some features. Nothing about it will ruin the battery.
    Dobrescu George likes this.
  11. icefalkon
    I don't use Tidal or Spotify....so wait until someone on here who uses it comes on. They'll be able to help you out.
  12. mrmoto050
    You will experience popping and studdering if your WiFi connection is 2.5G and not 5G at least that's my experience.
  13. icefalkon
    Well there you go.
  14. hung031086
    Just tried a few songs with Tidal offline and online. I heard popping sound almost everytime i changed songs. And it happened on both online and offline. If i let it auto change song after done, no popping sound.
    I used latest Lurker FW and 5.0GHZ wifi.
  15. mrmoto050
    Oh, I haven't experienced that, I usually just listen to a full album at a time, I also use cross fade settings. Maybe it has something to do with shuffle play?
