Really? And how do you expect a firmware update will fix your problems with the WiFi antenna if that is not working properly? RMA and buy direct from iBasso.com
I am sending it back.
Was it the DX200 that it was recommended to connect to 5ghz wifi and not 2ghz?
i can`t recall.
could be a possible fix
Open Box means it's a used product. Period. That's a reason I'm pretty sure you didn't pay full price for your dx200. Many stores even have a policy where open box sales are final and they are not responsible for after sales. I'm glad this store accepted the return/exchange.
No store going to open a boxed, mod dap with a custom fw, and sell it used, you know it. It's a return, and they should have checked it before selling it, at least to make sure it's in a default factory setup with original fw. But I'm glad to hear they are taking care of it!
As previously mentioned, I've had two DX200's previously, that functioned perfectly with my current wi-fi.
Hello everyone, is anyone using the AMP3 module with their DX200?
There are only two reviews on head-fi, and it seems their sound impressions are a bit conflicted. It'd be nice to get some further impressions before I upgrade and have to get 2.5mm cables for all my headphones/IEMs Thanks
Try to install WiFi Analyzer and check with it. It may happen, your router uses the channel which DX200 does not recognize. The available channels may depend on country settings.
So, just to recap, if anyone can spot what's going on. It has had Lurker's firmware install before I received it.
1 - No Wi-Fi. Finds the router, accepts the password, but no strength. My previous two DX200's worked fine, as do all other Wi-Fi enabled devices (Laptops, FiiO X7ii & Sky box).
2 - HibyMusic plays the songs in the correct order.
3 - Mango player plays songs in the correct order in Mango mode.
4 - Mango player doesn't play in the correct order in Android mode, despite the song number going up sequentially (1, 2, 3 etc).
I've cleared the cache, done a "Network settings reset" and "factory data reset".
I'm hesitant to download the latest official firmware and do a local update, in case I invalidate my ability to RMA it back to advancedmp3players.co.uk.
For the record, now I've calmed down from the frustration and disappointment of last night, I would like to keep the DX200, but only if I can resolve the above issues.
So, for the ultimate conclusion and part finale of Dx200+Amp3 Vs WM1Z. Your take . Here is how I see them
https://www.head-fi.org/threads/sony-nw-wm1z-wm1a.815841/page-993#post-13753229
