donjigantes
- May 8, 2016
Do you want the Hugo or the DX200 to produce the sound? Which will you plug your headphones into?
Hugo2
i believe you and thank you again. mine was just curiosity not criticBenchmark puts a connecting balanced to unbalanced howto in their audio installation guide, page 15, section 5.4. I think they know what they are taking about. http://cdn.shopify.com/s/files/1/0321/7609/files/caig_d61742b8-dde9-4870-b7ad-67ccb7a4e146.pdf?274
I always stated out this rule of thumb
Balanced to Balanced only, and Single Ended to Single Ended only.
The only time for exception is when you have a Balanced in and want to plug it into a Single Ended out. Fe, any Balanced headphones into a Single Ended DAP, Amps.....or Single-Ended player into a Balanced in amplifier. It is ok to split the signals up, but it is not ok to joined them up, period.
hey dx200 owners. couldn't find info on the amp modules' soundstage. does amp2 or amp3 increase soundstage depth? Thinking of maaaayybe getting this for my laylas but shallow soundstage is worrying...
Hugo2
Amp3 has better depth and width vs amp1 (Balanced 2.5mm out)
Nice to hear... Does this take the combo to WMZ1 and AK380 with amp levels? Or are there still layering issues present...
Ok...there are a lot of messed up info here that can blow my mind.....but hey, never connect Balanced out to Unbalanced in, period. I am not going to open that can of worm regarding differential and feedback circuitry.....then again...that is Unbalanced Out into Balanced in....You never connect Balanced out into Unbalanced in, if you don't get this.....I refuse to keep on this explanation
And the next, Coax/SPDIF is digital ***, and Amp1 has not that slot. Dx200 has Coax/Spdif, but it is atop the player
@irablumberg That you for the explanation. adapting Balanced to unbalanced is not optimal but it is feasible.
You don't need to explain anything to me. I understand quite well. Like I said this is used in pro audio sometimes. Adapting balanced to unbalanced or vice versa is not optimal but sometimes is needed. I'll post another link to a pro audio company that again shows you how to adapt these two typologies together. If this was taboo or a no no would a pro audio firm post this?
https://www.presonus.com/learn/technical-articles/balanced-unbalanced
You are keeping on showing me what I "already known"
You can use Single Ended out into Balanced in
Though you can not use Balanced out to connect into Single Ended in.
