DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Aug 21, 2017 at 7:51 PM Post #7,802 of 21,930
ctaxxxx
United States
Switching between AMP2 and AMP3 with the Fostex TH-900 mk2 headphones: the AMP3 sounds clearer in the highs, tighter in the bass, and is about 10-15 steps louder. These feel like a mix of AMP1 and AMP2.
Compared to the Liquid Carbon desktop amp (via LO through AMP1): The LC is closest to AMP2 in terms of tonality. Treble and vocals are a little smoother, but the bass is not as tight as AMP3. Overall, both smooth over the sound, but in different ways. A little hard to explain, but I think I prefer the AMP3 over the Liquid Carbon.
The best thing about AMP3 though is the tighter, punchier bass when I EQ it up! I always felt AMP2 kind of fell apart at this.
Altogether, I'm very impressed! Definitely do not regret going fully portable now that I have something to drive full sized headphones in the palm of my hand. I can use that money for other headphones now lol :grin:
Aug 21, 2017 at 8:02 PM Post #7,803 of 21,930
meomap
California
Hi,
Just received AMP3 this morning from DHL.
Power off, installed AMP3, power on DX200.
Plugged in 2.5 mm connector from DHC cable with K10C then HISSSSS non stop until I pushed PLAY.
Stop, idle = No Hissss
Tried to power off the unit. Power on again and Hiss even during SW loading up.
Pressed PLAY and the hiss is gone.
Does anyone owning the new AMP3 has this kind of Hiss?
I don't believe I have this Hiss with AMP1 or AMP2
FW still 2.3
Heard too many problems so far for 2.4 or 2.5 fw.
Aug 21, 2017 at 8:05 PM Post #7,804 of 21,930
artpiggo
Bangkok, Thailand
Hi,
FW still 2.3
You need to go 2.5 fw cuz there is update regarding amp3 compatibility
Aug 21, 2017 at 8:22 PM Post #7,807 of 21,930
meomap
California
Hi,
Is AMP3 Line Out also balance only?
Does it mean I cannot use 3.5 mm to RCA cable connecting to my ALO SS6 tube amp?
I need to know since I don't want burn out any unit testing it.
Even using Utopia with 2.5 mm balance cable connected to DX200 sounds great; however, connected DX200 ( use as transport ) to ALO SS6 is super open more for Utopia, more breathing air. Even Aeon hp with DX200 + SS6 sound very good but not like Utopia though.
Thank you for any feedback.
Aug 21, 2017 at 9:11 PM Post #7,808 of 21,930
artpiggo
Bangkok, Thailand
Hi,
Balance only cannot connect to single end amp by any method.
Aug 21, 2017 at 10:54 PM Post #7,810 of 21,930
chungjun
AMP1 - Mixed, SE & Bal
AMP2 - Single-Ended
AMP3 - Balanced
AMP4 - ?
I wonder...
Aug 21, 2017 at 10:57 PM Post #7,811 of 21,930
Time for burn in!
Aug 21, 2017 at 11:07 PM Post #7,812 of 21,930
Signal2Noise
Wherever the music takes me
Burn-in is overrated. I liked the Amp3 the minute I listened to it straight out of the box. I'll grow old with it simultaneously.
Aug 21, 2017 at 11:20 PM Post #7,813 of 21,930
Morimoriya 62
IRAN Tehran
Hi guys
Here I would like to ask a question,If someone has the same experience Please advise .
Is it correct Dx200 not the same level as Sony WMZ1,Ak380 cu or Sp 1000 AK ?only SQ Subject is review.
Regards Mori
Aug 21, 2017 at 11:52 PM Post #7,814 of 21,930
artpiggo
Bangkok, Thailand
AMP2 - Single-Ended
AMP3 - Balanced
AMP4 - ?
I wonder...
Paul said in the first page. AMP4 will be a surprise connection.
so it could be 4.4 balance which I am not involved in this.
AMP5 would be a previously-designed AMP4 in CanJam London so another high current single end.
I'm looking for AMP6,7,8 :darthsmile:
Aug 22, 2017 at 1:08 AM Post #7,815 of 21,930
WindowsX
Member of the Trade: Fidelizer Audio
This is how I interpret the way AMP module design they plan to release.
AMP1 - Best design they can come up with both SE/Bal output
AMP2 - Current mode Single-ended design
AMP3 - High voltage Balanced for hard to drive headphones
It's like additional amp module is for specialized application. I modded AMP1 module intensively and I could say with confidence that the design was already good. It can be improved with better parts and op amp sets. I hope iBasso will release improved AMP1 version in future. :)
Regards,
Keetakawee
