Hello
i wild buy the ibasso dx200 and ( i don't know now, cable effect audio eros II+ ), my actual iem is shure se846 and i'm looking for upgrade
I'm like listen metal: death metal, melodic and folk is my favorite.
I'm looking for iem for dx200 ( good match ) with this caracteristic:
My ears are sensitive to much-highs.
- Tight bass
- Transparent sound
- Good recovery of details
- Great extention of high
- Seperation sound ( guittars don't touch crash, hi-hat etc. Is hard this part in metal music, in rock, jazz i think is more eas because is more slow. )
I like aggresive iems.
Thanks for all !
1000usd - max 2000usd ~
Hi bro, we actually have almost the same gear... Ibasso Dx200 and SE846.. except that I use the upgrade cable from Fiio which is SPC.
From your target cable, Eros +, I havent tried it, but I have tried other cables from EA, Lionheart, Leonidas, Thor during Canjam Singapore last 2 weeks... I found them great and I love them all.
Clean and detailed, separation is there.
The Eros+ being hybrid, I can compare to same type being hybrid to another cable I have tried from different brand.
The cable I tried is similar specs and I can justify being neutral I can hear the bass clearly, the kickdrums and snare is balanced not to piercing.
The GUitar distortion is clear and does not sound thin (I tried tornado of souls by Megadeth).
For vocals I tried Journey's usual songs, and I find it clear too. the synths appeared clear and separation of it from guitar rythms and layers is defined.
Bass guitars also is clear and I can hear what is being played note per note. (I also tried Periphery, Nightwish and Kamelot on this)
I you are sensitive to highs, you are good to have hybrid since you need to push a bit of low and mids by the copper.
Adding silver makes neutral since using copper only will probabaly strange too you since the coloring is so much strong.
I would say go for it or try at first hybrids... have copper and silver alone not SPC.
Being in the similar genre, I am too planning to go for hybrid soon.
Hope this helps.
