DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
332 333 334 335 336 337 338 339 340 341
343 344 345 346 347 348 349 350 351 352
  1. artpiggo
    It seems like you need either granbeat or vivo xplay6 lol.
    Joking. The device doesn't feel slow at all. It is the best DAP UI ibasso can provide. It is not smartphone or onkyo ui smoothness level though.
    Try to use 5G channel wifi and near the router. It will solve problem. Until they fix 2.4G noise issue someday.
    Moonstar likes this.
  2. jamato8 Contributor
    I don't use Wifi much but have read a number of times to use the highest speed, 5ghz. I find the CPU to be very fast and download to be right up there and faster than any of my other daps.
  3. Moonstar
    @artpiggo @jamato8 Thank you for your quick reply. Happy to hear that the dx200 a capable device. Maybe I did something wrong :)
  4. Olchon
    This has been reported and I hope will be fixed with the next FW. It doesn't happen in Mango OS (unless you turn off then turn on again, when the album playing is rearranged in alphabetical order).
    Funnily enough, I thought I did have the problem in Mango - I was playing Radiohead, Moon Shaped Pool and I thought, "Damn, all these tracks have been rearranged alphabetically". Then I realised the proper track order IS actually in alphabetical order. I guess that's how Radiohead designed it...!:cool:
  5. bluesnote
    sharing the photo od my DX200 and SE846. [​IMG]
  6. AnakChan Moderator
    I'm finally getting some DX200 time! My DAP cradle :-
    So for the past few days I've done away with the burn-in dongle and used my earphones instead and it's doing so nicely.
    The DX200 is quite articulate. It pairs well with the likes of the FitEar MH335DW-SR which is a warm (DW - double woofer) earphone. Sonically to me it's a great sounding DAP for it's asking price. Software wise I think there's room for improvement.
    In many ways I find parallels with this and the DX100 which was also a great sounding DAP (one of, if not, the best of its time) but limited by its software (or the software demands on its hardware CPU/mem).
    I've got a long weekend holiday with the family and plan to use the DX200 the whole trip.
  7. twister6 Contributor
    OK, just finished and published my DX200 review, HERE.  A long read, including lots of comparison to other flagship DAPs and pair-up analysis with a ton of iem/full size.  Will have it officially on head-fi next week once I have everything polished.
    proedros, froger, x RELIC x and 2 others like this.
  8. Bastianpp
    Someone test effect audio eros II+? , i think of buy it and dx200 for my shure se846
    MunDa likes this.
  9. HiFiChris Contributor
    Benchmark tests indicate otherwise (yes, its CPU isn't as quick as current smartphones/tablet computers but still anything but slow):
  10. kevindiu
    Can we bypass android DSP and decode music source directly on the DAC using 3rd party apps??
  11. proedros
    great review , as always [​IMG]
    btw i want to ask something that caught my eye
    you say when comparing sources
    DX200 vs Micro iDSD – with iEMatch on Micro the hissing could be completely eliminated, but when it’s disabled – the hissing level is on par with DX200. Very similar soundstage expansion. Micro sounds a little brighter while DX is a touch smoother in comparison. In terms of detail retrieval, resolution, transparency, and sound layering they are very similar.
    so , if i have idsd micro already i assume that getting dx200 (sound-wise only) would be reduntant ?
  12. Moonstar
    Looks like I should format my device and give it a second chance. Thank you for all of this informations :)
  13. SoLost
    Oh this is good to know. Sorry I didn't read through all 341 pages of posts, so I am sure I missed a lot of info. Thanks.
    btw, do you all use Mango as the AP? or do you use some other software?
    I also find the screen to be very insensitive. I have to press really hard to get it to respond.
  14. SoLost
    Another question.
    I am using the Shure KSE1500. I first tried using the Line Out from the DX200 into the Shure Amp, but the volume was very low even if I have Gain on High, and Volume on the Shure amp up all the way. It doesn't feel right to use Phone out and crank up the volume.... is this normal?
  15. Crazypaladin
    I am using the KSE1500 too. In a previous firmware, 1.3.xx, the line out of the DX200 is full volume and my KSE1500 volume at 8-9 is very loud for me. The new firmware 2.xx allows line out volume to be variable and hence you might want to crank up the volume of DX200 line out to max. One more thing, when at max volume of DX200, absolutely no hiss or statics was picked up by the KSE1500 without the need for delimiter to be set at -10db or -20db.
