From 100% to 75% almost 2 hours of music, just tested. I don't know if this help. Make 2-3 full charges on the battery, I always do that with new smartphones, laptops etc.
I bought it since first month of its release date. Charges more than 40 times. In first hour with 100%, it drains 16% and later is around 13-14% .
Thats what i always do too!! 3-5 full charges & discharges. May be the placebo effect but for me it works!
Lower of course . I think it was 50-60/150, low gain. All this is in SE, the DX200 is pretty powerful.
Really benefited when Ni-MH batteries were used. Not really necessary with Li-Po's. But old habits are sometimes hard to break. I do the same. Sent from my iPhone using Tapatalk
That's Loud! 95 with my Z1R is loud in high gain. But Tidal is by default louder than average and louder than Spotify. But agree the Solar sound wonderful loud but not healthy for my ears .
We will not downsample music. We are working on fixes to all issues. I do not have a date at this time but it is being worked on 6 days a week. At this time I don't have a list of the features. As normal with our releases they will be listed.
My DX is dead. I was listening to my Stax set, feeding it with DX200 through line out. When I realised there is 3% of battery i plugged a charger. After couple minutes DX turned off and I can't get it charging from then. Two different cables and two chargers from Galaxy S7. My PC usb does not work either. DX was warm/hot every time connected to a charger before. Now it's cold, nothing happens at all.
You mention that you have tried two different cables, so I guess that isn't the problem. I have a USB cable that wasn't working and I very slightly crimped it with some pliers and it was fine. You tried it with two different chargers and your PC?
To be specific, three different chargers, two PC's and two different cables, stock included. I have no idea what should I do now.
