blazinblazin
- Nov 19, 2015
I get average 20hrs of use on WM1A though
what do you guys think,compare DX200 to WM1A?
The following site will cut a custom size tempered glass screen protector for the DX200.
http://protectionfilms24.com/products/screen-protectors/custom-sizes.html?pid=27 Select the Brotect AirGlass product if it is not already selected.
I have one installed. The measurements I used were:
Height: 112.7 mm
Width: 61.1 mm
Corner Radius: 0.1 mm
Measured with vernier calipers. The measurements should fit edge to edge. Deduct 0.1 mm from height and width for a buffer to install if needed.
Believe me, I would not say that I thought it was a hardware issue unless I had tried every software-related option, including updating the firmware, resetting the unit a bunch of times, and even doing a factory reset.
I'm wondering if all of the units with this problem were purchased on Amazon U.S. Has anyone who bought their DX200 on Amazon U.S. not experienced issues after using it for more than two weeks or so? My problems popped up after I had used it for 12 days.
I agree that the sound is incredible, but the UI issues rendered it unusable sometimes, and irritating most times. I just want to get one that works properly!
Height: 112.7 mm
Width: 61.1 mm
does DX200 or WM1A fits andromeda more?
Technically, dx200 is definitely better than Wm1a, in terms of analytical ability, soundstage, imaging and separation. With dx200, you can simply hear more details than wm1a. DX200 is just a beast of analytical ability. Technically, not even wm1z, ak320 and ak240 can beat DX200. But there's always the consideration of personal preference. wm1z/a is more warm and bassy, but they just can't perform the details and airiness and precision of dx200.
Planning to get a usb-c otg cable made. I know that the DX200 have a USB DAC Mode but I want to know does the DX200 have USB Digital Audio Out Mode (eg. where using the DX200 as transport to connect to external dac via the USB?)
I've joined the family thank you to Paul (mind you I've not paid for it yet - so much trust, iBasso! But I'll promise soon! Thank you iBasso).
