DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
294 295 296 297 298 299 300 301 302 303
305 306 307 308 309 310 311 312 313 314
  1. wirefriend
    http://www.head-fi.org/t/791531/dx200-details-features-and-specifications-1st-page-with-wifi-and-bluetooth-interchangeable-amps/2160#post_13151152
    BTW: there are also filter graphs embedded into DX200's UI itself.
  2. Moonstar
    @WindowsX I am trying to install you firmware. I have installed the Rockchip Usb driver for Windows8 64Bit. But when i open the app FactoryTool.exe i am getting the message "loading config file failed". Anyway the app is starting but when i select the update.img the app is crashing. What should i do?
  3. jamato8 Contributor
    I have the Sony WM1Z here and burning it in. It is more euphonic sounding compared to the WM1A and the DX200.  The Dx200 is more more neutral. Both are great to listen to. I prefer balanced on both and to me, the 1Z does sound different than the WM1A. To me, the WM1Z is better and a better match to the DX200 because they are different. I am using the Focal Utopia and various formats.
  4. Mizukage
    Is this for windows 10 to recognize the dx200 or to use dx as a DAC?
  5. Olchon
    To use the DX200 as a dac.
    At the moment I am connecting, turning on dac mode (tried in both Mango OS and android), dx200 shows up as "other" in device manager, but windows will not find the driver when I try to update it.
  6. Mizukage
    unzip the IBASSO_USB_Audio_v3.34.0.rar file and run the .exe file.  After that's done plug in the dx200 and enable the DAC ( I usually do it through Mango), and it should come up as a device to manage in the control panel under sound. Don't forget to go to Properties --> Advanced to set the quality you want.  Mine defaulted to cd quality.
  7. jamespitt
    Thanks for your reply. hoping its an isolated issue with a few of them only!
  8. frankrondaniel
    Sounds like many folks haven't experienced this problem.  To his credit, Paul from Ibasso offered to help.  Hopefully simply getting a replacement from the vendor will do the trick.
  9. Olchon
    Thanks, but failing at the first step! How do I unzip the rar file? There is no option to do this. Do I need to download an unzipper?
  10. Mizukage
    Yes, you need something like 7-zip which will open .rar files.
  11. Olchon
    Thanks, you're a star. Up and running....
  12. Mizukage
    Happy to help [​IMG]
  13. gr8soundz
    Has anyone compared how the DX200 sounds compared to the DX100?
    Was listening to my R10 last night (running Russian firmware) and wondering what audible differences I might hear with the DX200.
  14. HiFlight
    I have owned the DX100 and IMO, all of the positive audio characteristics have been improved. From a software standpoint the current firmware is more stable and user-friendly that that of the DX100. From a hardware standpoint, the WiFi reception capability of the DX200 is far and away superior to that of the DX100. Battery life is fairly close between the two, depending on the bit-rate and sample rate of the files played. Perhaps an hour better with the DX200.
    Hope this is of some help to you,
  15. gr8soundz
    Thanks.
    Never use wifi on my R10 since only the stock player can use the ESS hardware (and because I've yet to stream Tidal HD at $20/mth).
    The custom firmware on mine improved audio quality and speed. Seems like (for me) the DX200 would mostly be an ergonomic upgrade.
