Check my photo post a couple of pages back.
For info
(Swipe twice to the right side of the mango player)
For info
Should be possible since it's android. If not probably enabling usb mass storage can be an option.
Last night I updated the FW to 1.3.60 on Android, but when I go back to Mango and check the version, it still shows 1.6.2, which has not change as from my memory. Is this normal? Which means the Mango and the Android are basically two different systems, updating one would not affect the other?
Did you update to the latest FW? I didn't notice this until I updated the FW.
USB mass storage is working.
Are you talking about inserting a flash drive into DX200 USB slot and the player can player music from it? Or DX200 act as a mass storage device when connected to a PC/Mac?
why dont take advantage of using other well-established full-featured players in andriod?
it's strange you keep asking for the stock player to do everything
Third party app now cannot provide native sampling rate. If you install neutron or hiby, it will say it resample to 44.1 kHz.
It make Hires and DSD songs not have fully benefits. Now stock player is the most top notch SQ compare to other third party app even the library management is not friendly.
Poweramp (alpha built) seems working well without downsampling to 44.1
Also we can change the look of lockscreen with Poweramp too. But I'm not sure if the app utilize full potential of DX200 or not
