DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
1429 1430 1431 1432 1433 1434 1435 1436 1437 1438
1440 1441 1442 1443 1444 1445 1446 1447 1448
  1. highfell
    Wanna share it ??? please ......... -:)
  2. AndrewH13
    is this a DX200 beta version George?
  3. Dobrescu George
    I am really sorry to both of you, I confused threads and thought this was the DX220 thread, I don't think there is one out quite yet for DX200, but I do guess that the changes that are coming to DX220, in regards to better volume integration with AMP9, will also come to DX200.
    highfell and Gordhifi like this.
  4. AndroidL
  5. Gordhifi
    That is my understanding.
    highfell and Dobrescu George like this.
  6. Andreeww
    I wonder if there is any input lag when using this as a dac for computers? Thanks
  7. pali
    None that I can perceive. I sometimes use it for gaming and it performs well.
  8. duyanh43
    Still no firmware updates for DX150/200 users with AMP9 :frowning2:
  9. gr8soundz
    I know. Strange that iBasso is making us wait but Fidelizer has updated ROMs based on the latest DX220 firmware:
    https://www.fidelizer-audio.com/portable-products/
    I installed Fidelizer 1.13 on my DX150 and can confirm AMP9 now has low and high gain settings.
    Still waiting for the official update from iBasso tailored to my device but, for now, Fidelizer may be a good option for the DX200. Installation is a bit more involved compared to official updates but I found as long as Verity is properly disabled (player should auto reboot if done correctly) the process goes smoothly.
  10. duyanh43
    I find it quite complicated to install Fidelizer ROM. I prefer Original with Lurker mod to further extend my battery life, still works perfectly. When Amp9 was released, the fw for dx200/150 came just a bit later but when it comes to this fw with high/low gain option it has been like 2 weeks now(?) This is sad, it is like iBasso is forcing us to upgrade to the latest model.
  11. gr8soundz
    Agreed. Not good making users of their other daps wait. I even emailed iBasso after getting AMP9 and suggested high/low settings for it should be in the next firmware. DX150 was also released after DX200 but no update for either yet. Wonder how long DX220 users will have to wait for updates once DX220 Max is released?
  12. Lurker0
    It does not mean it works. Just like DF filter settings from DX220 are there but they don't work on DX150.
  13. gr8soundz
    I'm able to flash firmware pretty easily now so I tried it anyway. For now, the extra power from AMP9 will do until official firmware arrives. I'm also hoping you will do a stable Mango OS option for DX150 after iBasso does their part. Thanks in advance.
    I posted my findings here on the latest Fidelizer:
    https://www.head-fi.org/threads/iba...nture-continues.874224/page-185#post-15232567
  14. duyanh43
    I also an advocate for the high/low gain idea, I commented on the DX220 thread because it is more crowded there. I don’t think the Max version will affect as much as it don't have interchangeable amp module.
  15. dkalgray
    Although no one else seems too interested in this PMEQ discussion, I thought I would just give a short update to the issue I was having with distortion. In the end what solved my issue was increasing the 'Q' on my PMEQ settings. Using a low 'Q' of 5 or less (on a 'peaking filter') I would get noticeable distortion of the bass (I'm boosting both 50 and 65 hz by 3 or 4 dB) but with 'Q' settings of 10 or more (I'm using 15 now) the distortion disappears. I'm not quite sure why, but I guess who cares if it works. Obviously increasing the 'Q' narrows the width of the frequency boost, but I'm not sure why that reduces the distortion I'm hearing. Now sounds great with my Shure KSE1200s.
