- Oct 14, 2013
I can see that “unsecured” solder joints without your red arrow. The one next to it is also questionable. You are definitely up into the cause of buzzing here.
Now, if the pad is lifted, your Amp8 is done for. If it isn’t lifted, then you can have it redone. However, my guess is that it is lifted. Did you mean the Tantalum Yellow cap is moving or is it the brown Nippon is moving ? Hopefully it is the Nippon
The Amp8 at this place especially is very easily lifted, and damaged. However, if a tech can lift the pad with this Amp8W mod, then he isn’t good. Both @edwardsean and @singleended5863 and others did successfully upgraded to Amp8W without lifting them
