You already got the first part right. You're looking for a good tech instead of trying to do it yourself. I'm reasonably good with a soldering iron so I thought I could handle the job, but it requires hot air reflowing, which really is its own skill. So find a tech who has experience in using a hot air rework station on surface mount components. You don't have to know what this is but If the tech doesn't know what this is do not give him your amp! If he tells you, "But, I'm reasonably good with a soldering iron," do not give him your amp!
Once you find someone who can do SMD board work they will most likely never have handled anything as delicate as the amp8 module. They've worked on hundreds or thousands of laptops, iPhones, playstations, etc. and so they assume this little board will be easy. They assume wrong. My tech has about a decade of surface mount experience and he wrecked my amp8 and told me that the traces are 2-3X more sensitive than anything he's ever seen. Tell your tech this: "The traces on this board are 2-3X more sensitive than anything you've ever seen. The pads are fragile and can easily lift off the board."
If your tech has a station with a preheater that is going to be a big help, though not absolutely necessary. My tech set his preheater to 200°C and the hot air gun to 240°C. However, these are not absolute figures at all. A different technique will change this and these display temps may not be all that accurate.
Here is the best advice I can give you, which may not really be right for you: Kiss your amp1 goodbye and give it to the tech. If I were exactly in your shoes, I would sacrifice my stock amp1 and let the tech practice on it to find the right temperatures, how quickly to ramp it up, and what the board and components will tolerate. Better that he lifts a pad or breaks a trace or fries a part on the amp1 than on the amp8. As I said, this may not be the right move for you. For me, once I got the amp8, amp1 never saw the light of day again. So, I would've gladly wrecked my amp1 instead of 2 amp8 modules–gladly.
All the best to you.
