DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
burningv
- Aug 9, 2010
Congratulations, when you have a bit of time maybe you can tell us if it cab drive full size headphones like LPG and battery life.
Looks really good and the screen is high resolution.
+1
Mimouille, could you also tell us how quickly the device charges with USB Type-C and if there's a search function to easily find songs, albums, and artists?
MusicJunky
Great impressions, Mimouille! Also tell us what the battery life is like after you've used it for a bit. This dap is really looking promising. Cheers.
Sound Eq
- Nov 9, 2013
it would be interesting to read how it compares to fiio x7, as the description of the sound signature seems to me to be close to fiio x7
@Mimouille does it have playstore ?
ltanasom
- May 10, 2015
@Mimouille
thanks for great post.
waiting to read more impression.
Mimouille
No
not sure about charging yet. I didn't find any search function, but browsing by album, artist, song and genre are easy.+1
jmills8
Previously known as bmiamihk, jmills2
If I can use a music app on the DX200 with the Mojo I will have the green light.
What about Tidal/Spotify? Play store is working?
soundblast75
- Nov 30, 2012
The boy is big, but not fat
T.R.A.N.C.E.
- Mar 24, 2010
I'm waiting for a dap using the beast that is AK4497EQ.
Dithyrambes
- Dec 8, 2014
Thx Mimouille....sounds like typical sabre sound implemented very well. I was hoping for the lushness like a sony but I guess the player sounds like it would work well as a direct dac outto something like a tube amp. Looking forward to maybe more tube sounding amp sections.
chungjun
- Nov 14, 2016
No
May have to be a while but will be good to know how the battery holds up too... with the default amp...
- Oct 14, 2013
Mimouille you meant dx200 is much better than WM1Z ?
Sound Eq
- Nov 9, 2013
@Mimouille you meant dx200 is much better than WM1Z ?
i do not think he meant it in this way, but from his impressions i am very eager to get one
Rockcoon
- Feb 23, 2015
As i understand dx200 is very close to lpg and sony, or even in the same league. Ofcourse it's just initial imressions of one person. Need more time and people to draw final conclusion
Total: 6 (members: 0, guests: 6)
