- Oct 14, 2013
Dx220 uses the same amp modules
There's quite a few companies that sell 4.4mm connectors. If you want the Pennticonn brand you can buy them here....Do they sell direct?
Is this one any better?There's quite a few companies that sell 4.4mm connectors. If you want the Pennticonn brand you can buy them here....
Yes Furutech makes some awesome connectors. They are my favorite hands down. They are just really expensive. One thing, you may need spacers to work correctly with the DX200.Is this one any better?
https://www.audiyo.com/cf-7445-r-carbon-fiber-pentaconn-4-4mm-trrrs-connector.html
I use the Furutech but not with the carbon fiber housing, see no need for it or the extra expense. I use Furutech for RCAs, 2.5, 3.5, 4.4 and 1/4 plugs.Is this one any better?
I think the Rhodium plating and the alloy Furutech uses makes a difference. Whether you like that difference is another story....I agree, it cost more and doesn’t do anything at all
I love Furutech
Oh yeah, I totally love Furutech. Their plugs and the technology they used on them are awesome....except pricing and counterfeit problems....LOLI think the Rhodium plating and the alloy Furutech uses makes a difference. Whether you like that difference is another story....
The plug on the carbon fiber housing or the full metal is the same material in either one. I prefer the looks of the metal housing as well over the carbon fiber shell. Also, carbon fiber shells are pretty cheap to make so I would think they would charge less for the carbon fiber model.I think the Rhodium plating and the alloy Furutech uses makes a difference. Whether you like that difference is another story....
Agreed. Cost is insane for what you get. But hey were audiophiles looking for the best so why not buy the best....Oh yeah, I totally love Furutech. Their plugs and the technology they used on them are awesome....except pricing and counterfeit problems....LOL
I agree with you. I like the metal housing model better too....The plug on the carbon fiber housing or the full metal is the same material in either one. I prefer the looks of the metal housing as well over the carbon fiber shell. Also, carbon fiber shells are pretty cheap to make so I would think they would charge less for the carbon fiber model.
Do you have a link for the 4.4 TRRRS Furutech plug without the Carbon fiber housing?! ThanksI use the Furutech but not with the carbon fiber housing, see no need for it or the extra expense. I use Furutech for RCAs, 2.5, 3.5, 4.4 and 1/4 plugs.
Spacers? Can you be more specific as I will need to let the cable builder know about this if he doesn’t already?Do you have a link for the 4.4 TRRRS Furutech plug without the Carbon fiber housing?! Thanks
I have bought from Moon Audio, fair prices and fast shipping.Do you have a link for the 4.4 TRRRS Furutech plug without the Carbon fiber housing?! Thanks
