DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Jan 16, 2019 at 9:00 AM Post #20,266 of 22,021
So...should the volume remain the same across all apps? I'm trying to troubleshoot a problem (spontaneous ear-bleed volume levels), which I managed to fix, but now I notice that the volume changes levels when I open different apps. Additionally, the volume listed at the very top of the screen doesn't match the volume level inside Neutron, for example. WTH?
Jan 16, 2019 at 9:29 AM Post #20,268 of 22,021
Hey guys,
amp8 arrived
Below how it appears the standard as it arrived me:
So, do I have to change only the orange one with the Nichicon 470uF ?
while the 4 capacitors are the grey one so I have to replace them too with the black one?
PS the tdk absorber could create some problem of heat dissipation?
@EggofSound
Jan 16, 2019 at 10:17 AM Post #20,270 of 22,021
iBasso DX200 with Amp 8, iBasso CA04 adapter to ALO Audio reference 8 2.5mm cable and Campfire Audio Solaris.
Where did you get that adapter? I don't see it on their site.
Jan 16, 2019 at 11:06 AM Post #20,276 of 22,021
iBasso Stay updated on iBasso at their sponsor profile on Head-Fi.
http://www.ibasso.com/ paul@ibasso.com
Jan 16, 2019 at 11:20 AM Post #20,278 of 22,021
4-5 hours is about right. But with a long album, say, David Gimour Rattle That Lock it can use 25% of the battery. I don't really like to run it down to 0% before I charge it either. So three albums like that and time to charge it.
Jan 16, 2019 at 11:49 AM Post #20,280 of 22,021
Embarrassed look
I misplaced the original straight adapter a day or two before this one arrived. Still looking for it.
I've tested both the original and the new CA04 and find there is no difference in sound.
