The DX208W sounds amazing with the SR1!
I hope that you are using Perforated pads too ?The DX208W sounds amazing with the SR1!
I think if you go one page back from about tablet you might find the system upgrade thing. That's how it was on mine.Is anyone else using Fidelizer Advanced Purist ROM (v1.01.006) plus Lurker add-on v13 missing the option for System Update under Settings > System > About Tablet? I can't find a way to do the upgrade to stock Oreo 1.05.036 using OTA method.
I've also tried using Search Settings, and while there is a result for "System Upgrade" when I search, clicking it brings me back to the main System settings page, with no way to start the update process. I have tried a restart and re-enabled google services from within Lurker add-on but no luck. I guess I could flash back to v1.01.006 stock using Factory Tool, then do the OTA update to v1.05.036. Just wondering if there is a simpler way.
Thanks!
Thanks!
I informed to fidelizer and he found the root cause and promise to fix in the next fw. For this time, flash stock 1.006 first and upgrade to 5.036 accordingly and you know next process already.
iBasso DX200 with Amp 8, iBasso CA04 adapter to ALO Audio reference 8 2.5mm cable and Campfire Audio Solaris.
Any different in term of sound quality for this CA04 and CA02 ?
Both also serve the same purpose that convert 2.5mm balanced to 4.4 balanced.
