DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP4 and AMP5. Latest FW 2.9.209
Discussion in 'Portable Source Gear' started by paul - ibasso, Dec 17, 2015.
918 919 920 921 922 923 924 925 926 927
929 930 931 932 933 934 935
  1. jasonho
    Waiting waiting and keep waiting......
    Vitaly2017 likes this.
  2. jerick70
    The iFi iDSD Micro BL or iCan SE will drive these nicely but you would need a transport like a phone or a DAP. That would give you two boxes so a no go.
    I would switch to different headphones like the Mr. Speaker Aeon Flow. They work really well with the DX200 and DX150.
    Mike-WI likes this.
  3. skingg
    My bad if this has been answered before, but where can I find iBasso daps in Tokyo? I've looked up e-earphones and they only have the DX80 while both Bic Camera and Yodobashi still carry the DX90j model.
  4. artpiggo
    Did you try contact https://twitter.com/iBasso_Tei
    I have seen he provides ibasso product event in Japan before.
  5. singleended5863
    Try this address:
    Distributor
    Hibino Intersound Corporation
    3-5-2 Konan Minato-Ku
    Tokyo Japan 108-0075
  6. Layman1
    Hey man!
    I don't really understand what 'discrete' means in this context?
    What are the likely advantages of this?
    And does it give any indication as the the kind of sound signature that we could expect?
    Well, no harm to ask :)
    obileye obiyemi likes this.
  7. SQ13
    I am not too sure of the sound, but by discrete, I assume it uses individual components such as resistor, capacitors and diode or op-amp instead of integrated components (chip). just hope it uses high tolerance military grade parts and it also opens option to mod the parts to change/improve the sound.
  8. Vitaly2017
    I think it will be like amp 4s wich was a redesing of amp to be better circuitry and connector than amp4. So it will be the best amp with pentaccon.
    What I really want is that it also can go lower on to sub bas to, like amp 3.
  9. Layman1
    Hey, thanks for the reply :)
    I should clarify I guess; I basically 'get' what discrete means (individual components as opposed to integrated ones).
    However, that's pretty much the limit of my knowledge on this topic.
    What I'm trying to find out is, what are the (audiophile) benefits traditionally associated with using a discrete setup?
    Predictions/wild guesses about how the use of this configuration might cause the AMP7/8 to sound?
    It'll give us something to do while we wait :p
    Apart from 'enjoying the music' of course, which I am about to go off and do right now :D
    HungryPanda likes this.
  10. skingg
    Thanks guys. Will try to contact them.
  11. Vitaly2017
    Hey folks can some one explain me if there is a google play service by default? Heard some one saying that its missing and to install an app you need to go threw a link?
    Can i get the native spotify app or tidal? Does spotify or tidal can have the offeline mode? Like on a phone.
  12. HiFlight
    No, Google Play or other Play support is not included by default, and is unlikely to be added in the future. One can, however, side-load apps quite easily and most work just fine. However lacking the other parts of the Play environment, your apps will not automatically update and my apps that you have paid for will only be installed as the basic free version.
    That said, Lurker0's custom DX200 firmware does include all of the necessary Play Store components and one can download via WiFi anything that can be done using a typical smartphone. That said, in order to install Lurker's excellent firmware, one requires the iBasso batch tool using either a PC or MAC. The most tedious part of the entire process is first installing the required Windows driver that is necessary to run the batch tool. This does only need to be done the first time.
    Read carefully the posts on the first page of this long thread for more detailed info on how this works.
    It is well worth the time and effort spent for the installation!
    Of course there is no requirement to use the batch tool for installation of iBasso's stock firmware updates.
  13. Vitaly2017
    Thanks for the info il go look into this. I really need my spotify app or its a no go for me unfortunately.
  14. Vitaly2017
    Hey lurker does your firmeare use bit perfect output via amp out put?
    I need higest quality sound possible that why i considered dx200 but your firmware does it do any bypases or its entirely processed via ibasso dac and amp plus do i lose all the features and settings that ibasso ui offers?
    Can we do usb otg output to external dac amp?
    Thanks
  15. HiFlight
    You might consider doing a search for all of Lurker0's posts as he has addressed these questions previously.
    Lurker0 and mrmoto050 like this.
