DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Jun 2, 2018 at 7:29 PM Post #13,771 of 22,021
Amp5 does it for me since I dont use balanced output as I never hear the difference
Jun 3, 2018 at 5:30 PM Post #13,773 of 22,021
Sorry, but I had to release 2.9.209-L1. The changes are:
  • Problem resolved: Mango can't play DSD in 2.9.209-L0.
  • Problem reported as resolved: those "cracks and pops" while track changing in Tidal, Spotify etc. Same solution as in 2.9.198-L1 back again.
Thank you so much, Lurker. The new release works perfectly and eventually the crack and pop noises have almost dissapeared completely. Good job!!!!
Jun 3, 2018 at 7:04 PM Post #13,774 of 22,021
Echoing the thanks on the cracks & pops fix in 2.9.209-L1. It makes using Tidal more pleasant!
Jun 3, 2018 at 7:42 PM Post #13,775 of 22,021
Soon Tidal will be absolute silence! :wink:
What do you mean by "eventually" & "almost disappeared"? It's either gone or it's not. And it wouldn't happen gradually over time.
Jun 4, 2018 at 6:52 AM Post #13,776 of 22,021
I've been using Lurker's firmware for a while now. An issue I continually encounter is youtube videos freezing. Whenever these occur the audio still plays even though the video is frozen. On these ocassions I have closed the video then reopened, but more often than not the same problem will happen again. This doesnt seem to happen for every video, but will happen more often than not. Has anyone else experienced this?
I updated to the latest firmware a few days ago, but I'm still seeing the same problem.
Jun 4, 2018 at 7:14 AM Post #13,777 of 22,021
In my tests, it happens to HD videos only.
Sometimes it's enough to turn display off, then on, and continue playback.
I have no idea how to fix it, and what the cause of it.
Jun 4, 2018 at 7:19 AM Post #13,778 of 22,021
Thanks for info. I think most of the videos I watch must be HD then.
Will try switching off the display next time.
Jun 4, 2018 at 10:59 AM Post #13,779 of 22,021
I mean that this issue was supposed to be solved with the last version of Lurker’s firmware, but I don’t know why I was still having it with Tidal.
With this new version the crack and pop annoying noises have almost disappeared completely. I haven’t used it for a long time yet, but in certain circumstances I’ve been able to hear some of these noises, but not as loud and not as often than with the previous version.
Jun 4, 2018 at 11:38 AM Post #13,780 of 22,021
Here's that adapter we were talking about. It's fantastic!
Jun 4, 2018 at 12:14 PM Post #13,783 of 22,021
I can tell no difference between the iBasso one and this one. I do like that it's flexible.
Jun 4, 2018 at 2:02 PM Post #13,784 of 22,021
