dsrk
Not fair marketing from HyBy side. "DTA" in R6 is no better than in DX200. Considering that HiBy didn't mention DSD in their table, "DTA" in R6 is worse: DX200 allows 3rd party apps to playback native DSD, and R6 does not.
Please remember: whatever claims you read from HiBy, bear in mind that Android API does not provide an opportunity for bit perfect playback of 24 and 32 bit integer samples! All that HiBy claims is only applicable to sample rates. There is no a way for bit perfect playback of 32/384 using only Android standard API!
On the other hand, DX200 does provide a way for 100% bit perfect playback of any PCM (up to 32/384) and DSD (up to DSD256 via DoP), without modifications of apps. HiBy Music is the example of such an app
The bottom line is: iBasso DX200 is the first, and still is the only DAP in the world, which allows the feature called "DTA" by HiBy. OK, with my firmware, but it does not really matter, because for any other DAP there is no a way at all.
And, just in case...
Considering SoC used, they are not fair here as well. The correct values are: "4xA53 cores" for R6 and "8xA53 cores" for DX200
3GB of RAM? Increase of the cost and power consumption, and no real benefits.
So, R6 is only better than DX200 by "stainless steel frame" and QC3.0, and worse in each and every other row in the table, excluding screen resolution, which is equal.
It certainly is not better than DX200 (it's excellent modular AMP design is hard to beat right now) according to the reviews so far but 3GB RAM is a welcome good for better performance especially for Android DAPs, $100 Xiaomi phone comes with 3GB RAM these days.
