EggofSound
And, for anyone who would love to achieve better extensions in Sub bass with a touchmore mid bass warmth and make it more articulated while more musical. Everything else is very well preserved
ECHU upgrades here
These have no Polar, so no need to worry about it
You just need to pay attentions that the ECHU is plastic film and side casing. You can not grab the ECHU on it side when it is hot, as you will deform it by pressure and ruin the caps. Can only touch by the tinned plate and or top/bottom side
Advised to also use Hot-air station with super low fan speed, steady motions and heat up all of them, take out, and replace all. For those who is more curious about ECHU and soldering techniques, check out the Data-sheets. **no lifting pads** here, but ECHU can melt like chocolate if you grab them on the sides, and also is 1/2 the size of a rice**. These is also a little larger than stock one, you just need to fit it right in on the marking and you are gold
Also, secure your 4.4mm socket. By heating up the whole Palace with hot gun throughout your 4.4mm socket will Fell out of it PCB. I did also clean up the solder here and redone with SS47 as my favorite solder too! Slightly bend-in the legs a bit for better contact-joins too!
**recommended** for people who performed EX on Amp8 and still crave for more musicality, liquidity and flows
Picture is Amp8-EX
ECHU-Links to Mouser
Panasonic PPS is a favorite I use with my DAI / DAC.
(Because the capacity is small, the available space is limited ...)
