zdogg
- Jul 19, 2004
Here's a question I'm having trouble figuring out: do DVD-audio players allow for digital (coaxial or optical) output of high res (96khz/24bit or greater) 2 channel signals? I know that 5.1 channel high res digital output is not possible currently, but how about two channel (for headphone listening)?
I recently got a Pioneer DV578 from best buy to try out as a DVD audio transport with my Benchmark DAC1. I've got a bunch of DVD-A's for use in my car system, and I've been itching to hear them in two channel high res on my hd650's.
Since the benchmark doesn't have an indicator display to tell you the sampling rate of the incoming digital signal, I hooked the optical line out to my Sony integrated receiver (which displays the input sample rate up to 96k) to check what the pioneer was putting out. I noticed that with most of my DVD Audios (Yes fragile, REM's greatest hits, Metallica, etc), even though the on-TV display noted that they were 96/24, the sony display said 48khz. This is even after I went into the pioneer menu and turned off "downsampling". The exception was the AIX Records demo disc, which output 96khz (and sounded phenomenal).
Is this a problem specific to this player, or is it some copy protection scheme used by all players with DVD audio format, or specific DVD audio discs? I'd really like to get a player I can use as a functional high rez transport. Thanks for any help and sorry to be so long winded...
