dighn
- Mar 25, 2002
My second set of balanced cable from Audeze for the LCD-2 is starting to go bad in the same way as the first set. Poor strain relief for the headphone connectors are causing the cable to be damaged over time.
I'm looking for a better set of replacement cable. Nothing fancy, just well-engineered cable that won't go bad after a couple of years of normal use and aren't too expensive (< $200). Any suggestions?
I'm hearing that the OEM cables are now using a better braided design. Is this true?
